performer system on 305 work good?
Old Dec 7, 2000 | 10:38 PM
tzweelz's Avatar
thinking of putting the edelbrock performer system on the 305 thats going in a s10 truck.
it'll be a daily driver/beater i guess the system carb, intake, cam, etc. is designed for a 5.7 and they made around 300+ w/ a 355 w/ 10.1 CR
i was thinking the performer on a 305 might be close to the RPM on a 350, what da ya think?
Old Dec 7, 2000 | 11:02 PM
R.O.B.'s Avatar
The problem is the heads. With the small chambers the 305 has, you cannot use performer heads. 1> valves will hit, they are 2.02/1.60, you need 1.95/1.50 for a 305. 2> 305's use 58cc heads, performers are 64cc heads. If you used these, it would lower compression to about 8:1.
But, if you use WorldProducts 305 torquer heads, you'll be just fine. I used my Desk Top Dyno2000, using a 600cfm carb, assuming the performer intake, WorldProducts heads, and Edelbrocks 2102 cam, along with stock exhaust manifolds, this setup is worth 262hp @5500 rpm. A nice set of headers will push you to 310hp.
Rob
'86 TA 305 TPI
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
