alternator not putting out a charge in my car.
Subscribe
Oct 22, 2003 | 02:04 PM
i took my alternator to autozone and the tested it. it tested well, put out right above 13 volts. my problem is in my wiring, i know that. now, my question is, what is necessary for the alternator to be hooked up correctly if it is in a non computer controlled 310. it is set up like any other sbc. the alternator is from my 2.8 that was originally in my car. 1989 rs. (if that matters in wiring diagrams). i have the connector that goes to the top side of the alternator from the v6. it has two wires in it. a red wire that goes to the starter, and then an orange/white striped wire that goes to the car. where does this wire go? then i have one wire coming from the battery to the starter. anything else? i guess what confuses me about the connector with two wires is, when i got it tested over at the parts store, their connector had three wires in it. red, orange/white, and a black/white(assuming this is ground) wire. my connector doesn't even have provision for this wire. does my problem make sense? did i word this well? can anyone help me? it's got me and my dad both scratching our chin hairs!
Reply 0
Oct 22, 2003 | 02:58 PM
here is the pic of the connector i am talking about, i really need help guys, this is like the last thing i have before getting my exhaust on so that i can drive it.
Reply 0
Oct 22, 2003 | 03:22 PM
Could try scratching top of head instead of chin's! LOL
Seriosly, Try posting on Electronics board. That's where all the wire freaks hang out!! Might have better luck there.
Reply 0
Oct 22, 2003 | 04:10 PM
thanks.
Reply 0
Oct 23, 2003 | 07:05 AM
The red wire that goes to the starter, there should be a fusible link on it down by the starter. Possibly that link is blown.
Reply 0
Oct 23, 2003 | 09:26 AM
i'll check that, if it's blown, how does one go about fixing that? can i just do away with the fuesable link?
Reply 0
Oct 23, 2003 | 12:28 PM
No, never do away with a fusible link. More serious problems can result. Fix is simple. Go to your local auto parts store and pick up a GM 16 gauge fusible link (less than $3). It will say GM on the package. Cut the old one out, splice in the new. If you get one that already has the ring on one end, be aware most likely that ring is to small for the starter stud.
Reply 0
Oct 24, 2003 | 12:24 AM
ok, cool, i will check it out. i am so close to getting to drive this thing! it's making my nuts! i haven't driven it since Jan. all i gotta do is fix this problem and then order my exhaust...
Reply 0
Subscribe
