Starter runs "in the air"
Old Oct 23, 2003 | 02:59 AM
german's Avatar
Car: 91`GTA
Engine: 305cui
Transmission: Borg Warner T5
Hope anyone can give me a hint to fix this problem.
I drive a 91`GTA 305cui 5G.
Now my problem: when the car is cold- most at morning when I start the car first the starter will run but the car will not start. I can hear the starter gear rotate its a high noise(no cranking noise) but it seems the gear isn`t at the flywheel it rotate in the starter. Then I turn the key back and make this procedure 2-4times and then it starts.
When the car is warm I don`t have problems to start.
I think the gear hang or something. Is there a way to open the starter so I can see the shaft from the gear? Maybe same grease on the shaft will help. I don`t wont to buy a new solenoid for 100$.
Maybe someone had pics how to open the starter?
Old Oct 23, 2003 | 05:18 AM
ede's Avatar
ede
i ithnk it's time for a new starter. not sure if you can buy parts for them any more, use to be machine shops rebuilt your parts on site, but not any more. it's pretty easy and straight forward to take one apart. get it off the engine and you'll see what you need to do, only a few screws hold it together
Old Oct 23, 2003 | 05:41 PM
Vader's Avatar
You may have a problem with the pinion gear not engaging fully (linkage wear) or the overrunning clutch (Bendix) slipping after the pinion gear engages the flywheel. Either way, the starter will need to be removed for inspection.
A new Bendix is about $20 here in the states. If you cannot get one locally for a reasonable cost, you might want to consider ordering one online and paying the additional shipping cost to Europe.
Old Oct 24, 2003 | 12:53 AM
german's Avatar
Car: 91`GTA
Engine: 305cui
Ok, thx for the tips.
Today I will have a look what exactly makes this probs.! I will post the results then.
Did you know a US-Online dealer how sends oversea? www.carparts.com had great prices but doesn`t send oversesa.
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
