idle problem
Old Oct 23, 2003 | 07:03 PM
chimes13's Avatar
Car: 1991 Z28
Engine: 5.7
idle problem
I replaced my stock throttle body with a Holley 52mm. I didn't have any idle problems before the swap. When I first started the car, it wouldn't hold idle. I replaced the IAC valve and the problem is still there. Any Ideas on what my problem could be? The car is a 1991 z28 350 tpi. Thanks.
Old Oct 23, 2003 | 09:20 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
sory
Old Oct 24, 2003 | 05:40 PM
chimes13's Avatar
Car: 1991 Z28
Engine: 5.7
Also the idle problem seems to be when the car is cold only. When the car warms up the idle seems to be fine. Someone must have an idea........ I tried searching and found some info but more would be helpful.
Thanks.
Old Oct 24, 2003 | 06:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Throttle linkage adjusted properly? Maybe the TPS improperly set? I don't have much experience with FI, but you didn't really say what it was doing... idleing high? stalling? idleing roughly?
Old Oct 24, 2003 | 07:36 PM
chimes13's Avatar
Car: 1991 Z28
Engine: 5.7
when the car is cold and you start it, it starts and shuts off. I have to hold the idle by pressing the gas....
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
