engine popping
Old Oct 24, 2003 | 09:52 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
engine popping
can some1 please help me i have a 91 camaro z28 convertible 305 auto and if im doing around 35 and floor it my engine starts poppng alot sounds kinda like water boiling lol well its not really funny but you get my point anybody else ever have this problem
Old Oct 24, 2003 | 10:16 PM
smithtc's Avatar
Have you "investigated" anything, yet...?
Last tune up (plugs, wires, distributor cap, rotor, coil, fuel filters, air filters, transmission tune up)?
Checked for vacuum leaks, wires against exhaust?
How many miles on the engine...catalytic converters?
Can you check for fuel pressure during WOT (wide open throttle)?
Eliminate the simple solutions 1st
Old Oct 24, 2003 | 10:22 PM
im going to do a complete tune up next week it has 70,000 miles on it
Old Oct 25, 2003 | 02:59 AM
Morley's Avatar
Just went through this on my 91 bird, Change the coolant temp sensor, they only cost $10 or less.
Old Oct 25, 2003 | 09:47 AM
did your car run perfectly normal until you floored it then it started popping and didnt go any where
Old Oct 25, 2003 | 10:15 AM
Morley's Avatar
Yep pretty much. If I went beyond 1/2 throttle it would stumble and not pick up also it had a poping noise in the engine that would sometimes make it to the exhaust.
Old Oct 25, 2003 | 11:01 PM
camarodude91's Avatar
My engine would make a backfiring noise when i would floor it too. My problem was that the cam had went bad.
Old Oct 25, 2003 | 11:13 PM
radiateu2's Avatar
How about a clogged catalytic converter. When they go bad and expand and contract they make a popping sound. The engine also boggs too.
Old Oct 26, 2003 | 01:56 AM
be quit i dont want to hear that
that popping sound also comes out of my pipes and when your cat is clogged doesnt it usually stink real bad or not and thank you guys so far im going to check all these things
Old Oct 26, 2003 | 02:11 AM
radiateu2's Avatar
Not all the time does a bad cat stink. Its just something to look into too. It would explain the loss of power. A compression check and a leak down test maybe a good place to start. The compression test could help rule out a bad cam burnt/cracked valve.
Old Oct 26, 2003 | 08:55 AM
could you please explain how to test compression
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
RazorN8
Jan 7, 2022 11:44 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
