what psi in tires
Old Oct 24, 2003 | 10:34 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
what psi in tires
i have a 91 camaro Z28 convertible with 245/50/16 sumitomo tires and was wondering what psi you guys keep in your tires its driven on a daily basis
Old Oct 25, 2003 | 01:13 AM
nathan2003's Avatar
Car: Camaro
so me running 40 psi is bad then i should drop them to 32-34 they look about flat then though ? ! !?
Old Oct 25, 2003 | 02:47 AM
Morley's Avatar
Go by the sticker on the driver's side door jamb, 30-32psi
Old Oct 25, 2003 | 09:27 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i use 36-38 on the front and 32-34 on the rear.
Old Oct 25, 2003 | 09:45 AM
thank you guys and thats what i used
30-32 and i thought the sidewalls on your tires only showed you the maximium psi but thank you anyway
Old Oct 25, 2003 | 10:18 AM
Morley's Avatar
Yes, that is the MAXIMUM safe pressure the mfg. puts on the sidewall.
Old Oct 25, 2003 | 10:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Start with the door jamb sticker spec and experiment a psi or 2 at a time from there. Chances are, you won't end up more than 3 or 4 psi away from that.
Most of the tires that I've had do best on my car with 34-35 front and 32-33 rear.
Old Oct 26, 2003 | 04:21 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i've had good luck running 35psi all around.
rb, how do you come up with such a number? is it just an experimentation thing?
Old Oct 26, 2003 | 07:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, just experimentation.... I look for both ends to react equally when hitting a bump like asmall step in the pavement, the correct wear pattern on the rears (too much psi will make them bald down the center), equal tire temp after a long run on the highway, etc.
Old Oct 26, 2003 | 07:12 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
After my experimentation I run 28 in the rear and 32 in the front. But then again I'm running summer only tires.
Old Oct 26, 2003 | 09:41 PM
nathan2003's Avatar
Car: Camaro
Old Oct 27, 2003 | 06:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
40 is definitely high. I've had mine down to 20 at the track and they look no different than at 28 on the street. Go figure. My Kumho's must have really stiff sidewalls.
Old Oct 28, 2003 | 10:23 AM
Daemorok's Avatar
It depends on the tire, low pro tires usually need a little more pressure... my kuhmos have a max of 44, i usually run 38-40 otherwise they look flat and feel flat when i drive.
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
customblackbird
Oct 1, 2015 04:30 PM
eustodp
Sep 20, 2015 05:09 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
