Busted Turn Signal Level
Old Dec 9, 2000 | 06:46 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
When I click clockwise to for right turn, the signal level doesn't stay. It works left wise though. What exactly do I go buy to replace. I have heard they are a bitch to put in. But I don't have the money to get some moron to do it. How much do these cancels run.... and is there a quick fix? Hopefully it's just one thing.
Old Dec 9, 2000 | 07:18 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Well I doubt it's the lever itself but those run about $110. The lever just plugs into the column with no fasteners and the only hard part is getting the wire right. You probably have to replace some switch inside the column itself...which COULD get messy...
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 170' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to have 3.73 posi...
Old Dec 10, 2000 | 03:01 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
There is a plastic ring with the clicking mechanism on it. it is about $40 from the dealer. I might need to get one for my 86 T/A cuz my turn signal doesn't always click to the center position which makes my drivers side brake light not turn on. You have to take off the steering wheel and take apart the steering column(sp?) to raplace the part. It's not too hard from what I hear, it just takes awhile to do. If you can, take yours apart first to see if you can fix the spring mechanism in there first, before buying a replacement.
Zepher
'86 Pontiac Trans Am WS6, 5 Speed:
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
WS6 Trans Am
Old Dec 10, 2000 | 06:14 PM
mike88RS's Avatar
what you describe sounds like a turn signal switch. they run 15-$20, and most any auto parts store has them. the hardest part of the whol job is guiding the wires down the column. step by step; remove steering wheel. remove the plastic disc behind where wheel was, rent or uy a lock plate remover and depress the plate far enough to remove the retainer ring from the column. now, you need to unscrew the hazard ****, then three screws behind the sitch(hint, to access the bottom one, move the directional in the RH turn position) disconnect wires at base of column, and reverse all steps.
any questions, email me
mike
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Randomtask2
Sep 7, 2015 05:06 PM
