Building motor with block still attached??
Old Oct 25, 2003 | 10:41 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
I was thinking about building my motor with the block still attached to the motor mounts. Has anyone ever done it before?
I wanna pretty much replace everything crank rods pistons cam heads but i would problay have to take out radiator and other misc front end parts to get the cam in. Anybody know where i can get some high compression 305 pistons?
Old Oct 25, 2003 | 10:46 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
You will need to take the engine out to get the oil pan off to take the crank out. I don't know of any other way.
Mark
Old Oct 25, 2003 | 10:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Not a good idea but an over haul could be done in the car just not the type your considering. Pull te engine tear it down let a machine shop clean, hone and order the correct parts. This way its done correct and if something does go wrong you have someone else to blame.
Old Oct 26, 2003 | 05:13 AM
ede's Avatar
ede
i'm sure lot of people have. why would you want to? it's more time and effort involved leaving it in than pulling it, plus you can't clean or machine it, plus there's just about no way to do cam bearings
Old Oct 26, 2003 | 09:44 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
yea i forgot about the cam bearings. It really seemed like a quicker way to get it done because i dont really have the resources to be able to pull the motor and i wasnt gunna get it machined i was gunna do all the cleaning myself but cleaning the block when its stil in the car might be messy.
Old Oct 26, 2003 | 09:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not to mention impossible...
Go rent a cherry-picker at your local rental yard. It'll be alot cheaper than a leaking, smoking, blowing-up half-a'ed Krylon rebuild, which you'll just have to pull out and do right anyway.... the second time, after wasting a whole bunch of time and money, and putting out twice as much effort trying to get out of doing work as the work itself.
Old Oct 26, 2003 | 01:38 PM
miker61588's Avatar
i have done it and its possible. but its very hard to keep eveything clean. also takes a lot longer then if you just pulled it out.
Old Oct 26, 2003 | 04:14 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
The Oil pan can be removed with the engine in, but it is a PITA. As for rebuilding the motor, if you really want to overhaul it in the engine bay, you can, but IMO that's more like a "I'm doing this so I can sell it" type of deal. If you want a really good rebuild, remove that motor, and save yourself the extra headaches. For all the work involved, I agree with the other guys, it's just easier to pull out. You can get high compression 305 pistons from summit racing if you are interested. Hope that helps.
Old Oct 26, 2003 | 06:04 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Think about it ...in order to pull the crank you have to pull the trans out to take off the flex plate. You're also gonna need to pull the heads off and everything else so the only thing holding you back from pulling the shortblock out would be 2 bolts so pulling the motor would be much easier and cleaner.
Old Oct 26, 2003 | 08:34 PM
miker61588's Avatar
hey 88IROC350TPI
whats your car run in the 1/4? thanks
Old Oct 28, 2003 | 11:06 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
my only prblem is that i dont have room to pull it in my garage and i live in a townhome and i'm not allowed to work on a car but i on any way its more about that i would have to pull the motor with the garage door open and someone seeing it.
Old Oct 28, 2003 | 12:04 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
To do the motor in the car is spending an hour to save 10 minutes. Your neighbors will have a greater chance of "catching you", because the tedious project will take longer.
Single bay garage? Back your car in to the garage and close the garage door. Pull the hood, drive shaft, trans, rad, harness, motor mount bolts, AC comp, PS pump, fuel lines, and exhaust manifolds, etc, etc...get it ready.
Bolt on a chain proper, so the engine will be balanced. Do all this w/the garage door closed.
Open the garage door, use the rented picker and yank the engine. You should be able to do it in about 10 minutes.
Put the engine to one side cover it, and close the garage door. put the hood back on the park the car out side, and bring the engine into the garage. Close the door. Now all that your neighbors know is that your car is parked in the driveway, and your garage door is closed. They should have no idea you're creating a MONSTER in there! lol
Old Oct 30, 2003 | 07:50 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
lol yea but my car isnt even registered cus i cant afford insurance just yet. but i always have my car hidden in the garage the people that i live around if they saw an engine hanging from a hoist out of my car they would be like wtf are you doing. but i decided i rather go with a 350 then stay with my 305 so i gunna have to pull it anyways so maybe i see if i can do it at my local gas station since they guys there are pretty cool.
Old Oct 30, 2003 | 10:17 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
That sucks. There should be no rules keeping your from working on your car in your own garage. Now outside maybe. Its probably a nice community and they don't want car parts everywhere. I live in a small town that is real nice. I did a engine swap in my driveway. *** it was hideous. I will never do that again. I felt bad for my mom and dad because the whole yard and everything looked terrible. LOL.
Next time im gonna bum my grandpas garage off him. It will be much easier that way. Huge 3 car garage...should be plenty of room
Old Oct 30, 2003 | 12:36 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Originally posted by raffi4
lol but i always have my car hidden in the garage the people that i live around if they saw an engine hanging from a hoist out of my car they would be like wtf are you doing.
My reaction to those people would be something like, "hey, blow me."
That is your own turf- if they've got a problem with that, break 'em off some.
S-D
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
