Compression question
Old Oct 26, 2003 | 02:06 PM
bohn333's Avatar
Car: 1987 Trans am
Whats the factory compression of a 89 5.7 IROC engine?
And what size combustion chamber do they have? Last and final question, what would the compression be with a stock L98 piston and 64cc vortex heads?
Old Oct 26, 2003 | 03:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The "book" says 9.3:1. Heads are spec'ed at 64cc.
Regardless of actual CR, if you put on a set of 64cc Vortecs, CR will remain the same.
Old Oct 27, 2003 | 03:33 AM
Quadrabog's Avatar
Car: '86 Monte Carlo SS
What's the correct replacement piston to maintain 9.3:1 when using 64cc heads? Dished or flattop?
Summit #'s
STL-H345NP30 9.35:1 w/ 64cc heads. Flattop, looks like the one to use.
STL-H423NP30 8.90:1 w/ 64cc heads. Dished, engine builder swears this is the right piston.
Anyone?
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
