Turn signal problem...
Old Oct 26, 2003 | 02:54 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
when i turn my turn signal on for a right turn the lights all light up but dont blink, my left turn signals work fine, i've verified all the bulbs are working and both sides are using the same exact bulbs.. they all work fine with the hazard lights on.. the only thing i can think of is the flasher unit it self, but wouldnt both sides be effected? any ideas?
Old Oct 26, 2003 | 03:07 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
The flasher unit is really cheap so go and get one and try. I use one from a chevy van.
Old Oct 26, 2003 | 08:31 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It sounds like a burnt bulb to me. If the flashers work fine on one side, then the flasher unit is OK. The hazards use a seperate flasher.
Pete
Old Oct 26, 2003 | 08:37 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Pete
Yuppers ...... the bulb Chevy's way of saying you got one burt out ......havent seen a flasher go ( yet )
Also .... this may help tooo ......... Same symptoms .......... the front plug is a little old ( I am assumeing ) and I think from all the bulb changes ..... she is a little flexable ..... so I tap it and it works ........
....first thing next season ..... I am wireing a new plug
Old Oct 27, 2003 | 07:03 PM
89RsPower!'s Avatar
see the thing is, i've replaced all the bulbs, matched the bulbs and made sure im using all the correct bulbs on both sides of the car, the only thing that i can think of is I wired in an older style front flasher fixture in on the other side because my old one was broken in an accident, the wiring appeared identical as did the bulbs it used, I simply had to modify it slightly to fit into my turn signal fixture, now that side works perfectly, but the other side that was not damaged does not. Do I need to get a build fixture for the correct year? is that my problem? would it disable the other side from working properly even with all the bulbs matched?
Old Oct 28, 2003 | 01:19 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
My flasher did.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
