best tool for porting?
Old Oct 28, 2003 | 11:24 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm planning on porting my plenium and tpi intake and maybe take a little off the runners.. whats the best tool to use? i have a complete porting kit with pretty much everything i could need, basically what i'm askin is what tool is best to use, my angle air die grinder, strainght angle air die gringer, or a straight angle electric? thanks!
Old Oct 28, 2003 | 11:29 AM
ede's Avatar
ede
die grinder and carbide cutters
Old Oct 28, 2003 | 12:42 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I would use an electric die grinder. They tend to have better support of the cutter. And unless you have a huge air compressor, the air die grinder will keep the compressor running almost non stop.
Old Oct 28, 2003 | 01:59 PM
89RsPower!'s Avatar
what should i pay the most attention to in porting the intake? it seems to have quite a bit of metal to work with.. how about the plenum? it looks pretty thin.... and the runners.. is there anything you can actually do to em other then clean em really good and do a light polish?
Old Oct 28, 2003 | 02:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you dont want to polish the intake
you want to polish the exhaust though.
Old Oct 28, 2003 | 02:22 PM
89RsPower!'s Avatar
porting a stock tpi intake and plenium... no exhaust involved... the heads were professionally done a few years back and actually flowtested and everything so I don't plan on touching them, I'm just trying to get the most I can out of this tpi system so I can hopefully pass emissions before swapping to an lt1 intake
Old Oct 28, 2003 | 02:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
doh...
when you said porting the intake, i was thinking heads.... lol
Old Oct 28, 2003 | 04:40 PM
Vader's Avatar
Check this file for some hints:
Plenum Porting.pdf
You'll need Adobe Acrobat Reader to view/access/print the file.
Old Oct 28, 2003 | 09:53 PM
89RsPower!'s Avatar
wow, thanks a lot thats more then I could have asked for, its actually step by step with pictures!! great information and exactly everything I was looking for!
92projectcamaro
Dec 8, 2015 12:25 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
