How to tell a 350
Old Dec 11, 2000 | 01:03 PM
Jason 85 IrocZ's Avatar
How to tell a 350
Hello
How do I tell if a engine is a 350? when out of the car(so no vin to go by). Where on the block are the numbers and what will the 350 numbers be?
Jamieson
85 Blue Super Charged Iroc-Z28 Camaro
79 TransAm
1991 RS
1999 Oklahoma Gathering
2000 SWMG
Old Dec 11, 2000 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Top of the bell housing flange, behind the driver's side head; get the casting # and look it up at
http://www.mortec.com/castnum.htm
Also, 350s often have a big "5.7" cast into teh block there, while 305s have a "5.0".
Old Dec 11, 2000 | 01:10 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
At the back of the block (trans flange, driver's side) is the block part number. On the front passenger side (infront of cylinder head) there is a pad that has the block code (three letters), build date, and corresponding partial VIN of the vehicle (if not a crate) it was originally installed in. See sig link for details.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Chevy Info --> MadMike's
Old Dec 12, 2000 | 02:06 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
If it still has a manifold on it, the 305 manifold has a grid on the front left side.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 12, 2000 | 01:16 PM
MRZ28HO's Avatar
Engine: was: L69
Actually, that is just a manifold design (asthetic) change. The manifolds for all SBC are the same regardless of CID, so that is not an accurrate way of decifering from a 305 and a 350.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
