Dual plane or single for me?
Old Oct 28, 2003 | 09:53 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Here's the car buildup:
former LG4
355 - L69 air cleaner(k&n) - rebuilt strip q-jet - weiand action plus(egr blocked) pn 8000 - edelbrock rpm heads - comp cams 280H magnum (230 degrees @ .05 / .480" lift) - crane gold roller rocker (1:6 ratio exhaust) - holley blue electric fuel pump - stewart water pump - hedman shorties w/ custom y-pipe - 3" magnaflow cat - flowmaster american thunder 3" catback - auburn posi w/3.73s - rebuilt T-5 - clutch fan - 14 degree advance
I'm thinking that with my cam I may benefit by converting to a single plane manifold, the weiand 7525 (supports q-jets).
My current manifold is supprisingly similar in design to the weiand stealth 8016, but is a little shorter and advertised to make power to 6000, so i figure it flows enough.
Any opinions?
Old Oct 29, 2003 | 05:12 AM
ede's Avatar
ede
duel
Old Oct 29, 2003 | 07:34 AM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
single with a smaller carb or dual with a bigger carb!!
Old Oct 29, 2003 | 09:26 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i say dual plane. is this a street car i assume? daily driver? track only?
Old Oct 29, 2003 | 11:12 AM
Bandit5's Avatar
Allthough you might be able to gain high end HP numbers with a single on that setup, the dual will help you out on the midrange and off idle, which you really need. I'd go with a Air Gap myself on that setup, pretty much the best of both worlds, though a dual plane intake nonetheless.
Old Oct 29, 2003 | 12:17 PM
iroc22's Avatar
Stick with the current manifold. As asked above, what duties is this car having to do?
Old Oct 29, 2003 | 04:54 PM
Manic Z's Avatar
I don't drive the car everyday because i have a work truck, but i try to drive it as much as possible nontheless.
Right now, it drives great and idles nicely. The midrange is awesome,and the top end is pretty good too.
If you look at the pictures of the various intakes, it seems to me that the pn 8000 (mine) has more in common with the stealth intake than it does with the non-egr action plus.
Look at the runner designs and the manifold height dimensions.
What do you guys think?
Old Oct 29, 2003 | 05:34 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I have the same intake, except my egr is still working. I think it flows plenty enough for anything up to a 350....an RPM air gap just may be a little better on the top end, not sure though.
IMO it's not worth changing.
LT1Formula
Oct 8, 2015 08:34 PM
zman1969
Oct 1, 2015 11:09 AM
