what material to fix radiator. Overflow neck came loose
Old Dec 13, 2000 | 09:28 AM
iroctpis's Avatar
its an aftermarket aluminum radiator, and I don't know what kind of epoxy to use to fix the leak from the overflow neck coming out of the radiator
89 iroc 5.7 can't go fast enough
Old Dec 13, 2000 | 10:01 AM
Box of Rocks's Avatar
SSSSHHHHH !!!
Don't tell anyone I told you this, because it's the waaaay hokey solution - although it will probably hold.
JB Weld - it's a 2-part epoxy and the schizz is strong like Bull.
BOR
Old Dec 13, 2000 | 05:21 PM
ede's Avatar
ede
if it were me i'd weld it. you may want to use the world famous JB Weld as BOR said, just tell any one that ask a old guy from kentuckey told you it'd work.
ICON Motorsports
1st & 3rd
Old Dec 14, 2000 | 12:22 AM
iroctpis's Avatar
ok thanks, any other suggestions?
89 iroc 5.7 can't go fast enough. 14.1
Old Dec 14, 2000 | 12:42 PM
Stuart Moss's Avatar
Just a thought, but depending upon how thick the filler neck is, you might want to consider taping it (1/8 NPT or ?) to accept a nipple that you could screw in.
You should be able to get just the tap for a couple dollars, plus a brass hose barb with the proper threads to attach it...
Bohemian
Aug 15, 2017 05:11 PM
92firebirdguy
Sep 1, 2016 07:53 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
TheTraut88
Sep 11, 2015 05:16 AM
