Pulleys 2 or 3 best setup
Old Dec 13, 2000 | 11:57 PM
smkin92's Avatar
I'm wanting to put underdrive pulleys on my 92 305 Camaro it already has headers,chip openair cleaner no smog pump. Now i talked to a guy and he said that a 2pc. set is better than a 3pc. set. He told me that a three piece set will set eerything back like it already was unlike the two piece set that will only make the crank an alt. turn slower. Is this true any help will be appreciated.
Old Dec 14, 2000 | 12:24 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Any reduction in pulley size is beneficial. Imagine spinning a rope with a heavy object (10lbs) attached 5 feet at the other end while you spin it around you (over your head). Give the rope 10 feet of slack, can you still turn it just as fast? What about at 1 foot? Easier huh? That's how pullies work, mind you, if the sizes aren't relative to each other some accessories could fail or not perform at optimum efficiency.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Chevy Info --> MadMike's
[This message has been edited by MRZ28HO (edited December 13, 2000).]
Old Dec 14, 2000 | 02:47 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I've got the 2 piece set on my car and I didn't notice any improvement. I really don't think that you'd notice any difference with the more expensive 3 piece set either. Therefore, if you just have to have a set, I would recommend the less expensive 2 piece set.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Dec 14, 2000 | 04:39 PM
daniel91rs's Avatar
I went with the three piece set but the on difference i noticed was that my alt. didn't charge as much. So i had to be careful when driving at night with my lights on because in a few cases, my car would shut off, and a few months later i had to replace the battery and the alt. I don't know if the pulleys had anything to do with killing it or not.
91RS 305-k&n,flowmaster, ASCD S.S. hood,March Pulleys
Pac J
May 17, 2020 10:44 AM
BDR
Nov 7, 2015 03:05 PM
2012sergen11
Oct 13, 2015 07:38 PM
tattmann
Sep 27, 2015 05:20 PM
evilstuie
Sep 24, 2015 02:31 AM
