typical engine wear (pics)
Is this wear (or lack of) typical for a 69,000 mile 305? There is no scuffing, no scratches, and just a tiny carbon ring around the tops of the cylinder bores. The little marks you see in there is just flash rust from some antifreeze that got in there when I pulled the heads.
No big hurry on getting this one answered, it's more of a curiosity thing than anything else
Thanks guys,
Matt
EDIT: I guess a pic would help out here
Thanks guys,
Matt
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Looks like your motor is in good shape. The ring is the usual because the pistons are shaped like junk from GM and the edges never reach TDC.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I wonder what my 125k mile L03 looks like inside...
I'll find out soon enough
lol, I wire wheeled the piston tops and all the gasket mating surfaces. My dad said that If I cleaned the carbon off the piston tops it will help prevent detonation. Glad to see you noticed
I was careful not to touch that carbon ring on the top of the bores though.
Matt
Matt
The only problem I see with decarbonizing pistons in the bore is the carbon usually winds up in the top ring land. The other problem is the coating on top of the piston is removed if a wire wheel is used over aggresively leading to faster carbon build up when the motor is running again. I see you didn't get too crazy and try to clean out the valve notches, which is when most people screw up and apply too much pressure with the wire wheel stripping the top of the piston.
Originally posted by Vader
He's correct. Sounds like you have a good resource right there alongside you.
I've sucked so much knowledge from him in the past 5 years, it ain't even funny. I don't know how I could have learned even 10% of what I know without his help.
And BTW, it's great to see you're back. I got kind of worried when one of the most helpful people on the board took off for personal reasons. I hope that whatever you had to take care of turned out for the best.
Take care fellas,
Matt
