Oil Pan Drain Plug Leak
Old Oct 31, 2003 | 08:12 PM
dsaint1347's Avatar
I hit a huge rock and it hit the oil pan, now I get a real bad oil leak from the drain plug. Someone told me to use thread sealing tape. Would that be safe to use till I get the pan replaced?
Old Oct 31, 2003 | 08:45 PM
Chet's Avatar
Car: GTA
This exact thing happen to a friend of mine. We bought an oversized drain plug and it was fine for a week until he had time to change the pan. When you change the pan I recommend getting the 1 piece from fel-pro.
Old Nov 1, 2003 | 07:03 AM
ede's Avatar
ede
why don't you just replace the gasket or use an o ring. thread seal tape won't do much with straight threads but i guess it'd be better than nothing. are you sure the leak is from the plug and not a crack somewhere near it
Old Nov 1, 2003 | 07:37 AM
dsaint1347's Avatar
Yes, I loosened it then retightened the sucker and it does drip a lot less. I think it may leak more when it gets hot? I should tighten it when it's hot right?
Old Nov 1, 2003 | 09:03 AM
BILLY SMITH's Avatar
i agree with chet ....go to NAPA and get the next available over size pan bolt it comes with ever thing required to complete the job works real good i repaired my jimmy pan with one
Old Nov 1, 2003 | 10:46 AM
dsaint1347's Avatar
I'll try it. Thanks
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
