Air Pump Pully Bypass? Is There A Kit?
Old Nov 2, 2003 | 05:45 PM
paul5.0's Avatar
Car: trans am 1991
I REMOVED ALL THE AIR PUMP HOSES AND VALVES THAT RUN TO THE CAT AND EXAUST MANIFOLDS. I ALSO WOULD LIKE TO REMOVE THE AIRPUMP, BUT IT SEEMS INPOSSIBLE FOR THE BELT TO CLEAR THE PULLEYS IF I DO. I HAVE A,C AND WOULD LIKE TO KEEP THE COMPRESSOR, BUT REMOVE THE AIR PUMP. IS THERE A WAY TO RE-ROUTE THE BELT, OR EVEN BETTER, IS THERE A KIT FOR THIS JOB.
THANK YOU
Old Nov 2, 2003 | 06:01 PM
azalbutt's Avatar
Car: 92 v6 firebird
Engine: 3.1
Transmission: 700 r4
smog pumps........
If you are talking about the smog pump, then if you removed the lines going to the cat, then you need to remove the cat too. not emmisoins legal, but necessary if you have cut off the air suply. Your cat needs the air from the smog pump to burn the raw fuel, thats the purpose of the whole thing. In time with the smog pump not functioning the cat wil clog and give you problems, so keep all this in mind. Now kinda silly I guess, but what a lot of guys used to do on the older V8s with smog, is take the air feed from the pump and route it to the intake for a lil extra power, but I'm not sure if this helps or not, but since you are messin with it, maybe try it for a laugh. why not, its a $5 hose that you can buy from any parts store.. Just remember to do something about the cat.......!!!!
Old Nov 2, 2003 | 09:09 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: smog pumps........
Are you sure about that?
Old Nov 2, 2003 | 11:09 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Yes, if you have a Cat that has an air inlet, with out the air coming in, it will clog up.. There are some cats that do not have a air inlet.. But I'm not sure if they would still work in a car that had the air pump system...
Old Nov 3, 2003 | 03:20 AM
azalbutt's Avatar
Car: 92 v6 firebird
Engine: 3.1
Kinda sticky subject
Well I'm absolutly sure because I used to work for an emissions testing shop in AZ. If the car has a cat, then it will usually have Some ways of pumping air into the exhaust. Where it connects, does not matter, but yours probably connects to the cat itself.. some connect to the exhaust manifold, tail pipe and thats about it. As far as a kit, you may be looking at a custom job by a good welder, or you can take the old smogpump out and gut it. This is possible, but make sure you have 45-65 bucks incase you screw the thing up so bad it wont turn again. Really the smog pump has very little restriction on your drive, and may rob a whopping 2 HP, but you'd be better off just reconnecting everything and leave that the way it was.. If your looking for power, get an underdrive pully set, and it should even have one for your pump. Cold air intake is a $40 job you can do and make yourself with the help of a 3" tube and cone airfilter. A good cam for $150 can add up to 35 hp and last but not least, if you ARE looking for great HP gains, blow the thing with a supercharger kit. Go to EBAY, they have em everywhere. Little fabrication and talking to the right people, you can supercharge any engine for under $500 contrary to belief.
By the way, don't ask about turbo's because I a have no idea, except for the fact that I prefer a supercharge over them because there's instant power for the take off that we are all looking for. Turbo's are great if you tryin to go 180mph because they stink at low end ranges, but kick in hard and heavy at high RPMs. They really do. A charger will be there whenever you need it, and if you put more boost than a small charger puts out into your engine, you'll blow it to peices...
Old Nov 3, 2003 | 04:43 AM
MdFormula350's Avatar
new belt routing, i needed a 2 inch bigger belt i believe.
Old Nov 3, 2003 | 12:36 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
When I removed mine I capped off my cat-co with a plug and I was assured by numerous people that this would have no ill effect on my cat. Multiple exhaust/race shops verified this to me as well.
Old Nov 3, 2003 | 01:04 PM
Steve89GTA's Avatar
I have had mine capped for 3 years now. Car passes emissions tests and drive perfect.
Old Nov 3, 2003 | 02:13 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
A longer belt will clear the other pullies fine. If you ever get rid of the AC you can route your belt like I have mine. 50'' serpentine belt with no pass side bracket at all
Old Nov 3, 2003 | 03:44 PM
azalbutt's Avatar
Car: 92 v6 firebird
Engine: 3.1
cats and pumps
slowly it will clog. get a highpass cat if you want, that will help your gains. remember that you are doing all of this to gain 2-3 HP by bypassing the pump. A/C, Alt, water pump (if it's belt driven), and stearing pump all draw considerably more power from your belt than your air pump. All it does is puff. not like you could even inflat a blow up doll with it. Thats how little it does. The cat is there to burn excess fuel, fuel needs fresh air. Maybe 5 years give or take a year you wont notice a difference, but rest assured when your car starts to run a little rich from wear and tear, or spark plugs wearing, your cat will plug up as soon as it does start running rich. Then again, maybe all the HOTROD guys say it wont, but be honest, how often are they tearing their engine apart either to tinker or to rebuild it. I like cars with power too, but I don't like ripping into the every couple of years because I wanted a few more horsies ya know. Think of the long run, and see whether something more permanant would last longer and give you more gain as will...........
Old Nov 3, 2003 | 05:44 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
How do you tension the belt?
Old Nov 3, 2003 | 07:20 PM
Transmission: 4l60e
I used a piece from an old style alt bracket...I need some pictures. I can't really explain it without pictures.
Remove the damn cat to if you worried about it clogging because of the smog pump tube being blocked...if you can remove it chances are you dont have emissions so do away with the cat and never worry about it again.
Old Nov 3, 2003 | 07:35 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
yeah, afaik FL has no emissions. just take out the cat, or at least gut it.
Old Nov 4, 2003 | 03:14 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
lol, nice art work guys. LMAO
Old Nov 5, 2003 | 07:59 AM
paul5.0's Avatar
Car: trans am 1991
FORGET THE CAT.
OK GUYS, LETS TAKE THE FOCUS OFF OF THE CAT FOR JUST A SECOND. OBVIOUSLY, IF IM GOING TO REMOVE THE "SMOG" PUMP AND ALL OF ITS COMPONENTS; I ALSO WILL BE REMOVING ANY OTHER EMISSIONS RELATED ITEMS. LIKE THE CAT. MY POINT WAS, HOW CAN I GET RID OF THAT UGLY SMOG PUMP, AND RE-ROUTE THE BELT? I WANT TO CLEAN UP THE ENGINE BAY. THANKS
Old Nov 5, 2003 | 08:06 AM
Steve89GTA's Avatar
Paul, there's a tech article on this site about it. I used that method and it worked perfect for me. You will need a longer belt. Mine was a little different that the belt length specified in the article but none the less, it all worked well...
Old Nov 5, 2003 | 01:07 PM
Transmission: 4l60e
Just take the smog pump out...get a longer belt and thats it. Thats all there is to it.
Glowsock
Jul 24, 2025 03:15 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
toronto formula
Nov 10, 2015 06:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
mcquigg
Aug 13, 2015 02:26 PM
