HELP! Can't get it started....
Old Dec 15, 2000 | 01:50 PM
Brent's Avatar
I'm working on a stock 86 Camaro w/LG4.
It is extremely hard to start. When it does start, it runs very rough. Firing only a couple of the cylinders. To keep the engine running at 1000rpm requires almost %25 throttle.
The following has happened.
around thanksgiving
Car began running very rough, low on power. <cr>
Next day would not restart.
the next week
a new module was installed <cr>
still won't start. <cr>
A timing chain was installed (old chain was fine) <cr>
still won't start <cr>
Spark plugs changed (very fouled) <cr>
Coil changed <cr>
The car starts and runs great. <cr>
Timing is adjusted to factory spec (off by 6 degrees) <cr>
Car continues to run good <cr>
one week later
the car loses power again, same as before <cr>
Module tests ok, pickup coil measures 739ohms (in spec) <cr>
Coil tests ok <cr>
can't get it started <cr>
A scan tool shows all sensors in range. <cr>
Please some one throw me a bone here. I'm stumped.
Old Dec 15, 2000 | 02:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Choke problem? Does it improve when it warms up?
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Old Dec 15, 2000 | 04:17 PM
Brent's Avatar
The choke was investigated. The choke heater is failing but it is not causing this problem. Wired the choke open.
This is a severe misfire.
Old Dec 15, 2000 | 05:16 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Well, the first thing i would do pull the plugs again.... maybe you have a problem in the carb with the m/c solenoid. Did you test the vacum to? is there any at all? (not that a half runnin car is gonna make much vacum) but the only thing that i can think of is at this point would be something wrong with the fuel system. if your sysmtem is a AFTER fire, then that would give you the reason to believe cyliders are not fires, AND there that there might be a rich condition...
Steve
Old Dec 15, 2000 | 06:14 PM
cica55's Avatar
well , I assume that this is about stuart's LG4 iroc...
anyway , as I've told him before and will keep saying , REPLACE that carb... I don't care if the choke seems to be okay or is hot wired, either borrow a good working one (could use mine if u guys didn't live so damn far away I even thought I would give stu my new q-jet for couple bucks but I need the engine and carb for another 6 months).
so , new q-jet is $170 or so , ask if you can return it if it doesn't solve your problem, and if so definitely get one... it takes 25 minutes to swap them so it's well worth it...
u guys should have done that before the "tune up", I would have changed the plugs , but I still think it's the stupid carb and that's it... (not sure what is wrong with it though, mine was acting all funny too, one day it runs , hmm I figured it doens't run well when it's cold , the next week it's 10 degrees outside and car runs even better, then it gets warmer and the stupid crappy thing starts messing everything up, so I threw it in the trash and got a new one... problem solved...)
U guys have replaced just about everything that can be easily replaced (+ timing chain), so why not try the carb...
Old Dec 15, 2000 | 06:19 PM
cica55's Avatar
stu keeps saying that it's the ignition , I can't say that he's right or wrong , but while you're at the carb, rip out the distributor too
(can't u guys borrow these from some "working" cars ??? that way it wouldn't cost u any money to try them all...)
RcZ28
Mid-West Region
Oct 6, 2013 06:06 AM
88fastgta
Oct 17, 2010 10:39 AM
IEatRice4dinner
Jun 9, 2008 08:22 PM
paul_huryk
Apr 12, 2005 09:30 AM
CD MaroMan 91
Car Audio
24
Nov 19, 2001 11:29 AM
