oil pressure problem
Old Nov 3, 2003 | 11:55 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
my car has about 127,000 miles on it . I have noticed that my oil pressure has started to drop little by little over the past few months. Well I just recently changed the oil pressure switch just to see if maybe the sensor was dirty. Well that did not work. Is my oil pump going out or is there something else that I should check. I am going to change the oil wed. and see if maybe the filter is just dirty. Any thoughts or comments would really help me out .
thanks in advance
Old Nov 4, 2003 | 05:14 AM
ede's Avatar
ede
10 psi per 1000 rpm is acceptable what is your oil preasure? might want to screw a mechanical gauge in the block somewhere and see what you really have
Old Nov 4, 2003 | 05:31 AM
Vader's Avatar
And if the mechanical gauge verifies what the dash gauge is indicating, you need to evaluate whether the oil and filter you are using are correct.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
