Replaced Camshaft, know engine cranks but does not fire
Old Nov 4, 2003 | 12:18 PM
tckeeper's Avatar
Replaced Camshaft, eradict rpm's and engine sputters out
Engine fired, problem was with TBI unit being clogged, but problems still exist, engine has an eradict idle and will sputter out, adjusted the timing, but with everything reconnected still have same engine problem. Thoughts - Oxygen Sensor bad, need open element filter, not enough air flow.
Also, the distributor contacts appear to be rusted and with the distributor out it does not spin freely, it feels like it is catching, I know the rust is not normaly, but should the distributor spin freely when it is out of the engine?
Any help would be great
Old Nov 4, 2003 | 12:45 PM
ede's Avatar
ede
does it not start or not fire? no fire might be the rust. if it fires but not start i'd be checking the timing and distributor instalation. might also have a wire not hooked up
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
