Spark Plug Tips
Old Dec 14, 2000 | 11:45 PM
Neo's Avatar
Neo
Spark Plug Tips
I am going to replace my spark plugs this weekend but those suckers are way down there and the compartment is cramped. Any suggestions on how to make this easier would be enjoyable. Thx.
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube in back
Future: 2" Cowl hood w/ K&N filter
Old Dec 15, 2000 | 04:37 AM
ede's Avatar
ede
the the easy ones from the top and then jack the car up and get the others from under the car. can't remember for sure which ones to get from under the car ,the rear 2 on each side maybe. you'll figure it out. while it's jacked up change the oil and grease it too.
ICON Motorsports
1st & 3rd
Old Dec 15, 2000 | 01:13 PM
84TransAm's Avatar
the hard ones to get at are cylinders 5 and 7 unless you get under the car, which makes it a piece of cake. Cylinder 8 is a bitch. Took me & a friend 30 min to magically take it out.
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock will soup up when i get some $$$$$$$$$$
Old Dec 15, 2000 | 01:43 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I was able to change out all but #8 from the top. #7 was a bitch - I had to lie across the intake on the engine to get my hands in there. If you have real long arms, you could probably change #8 from the top too.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
Old Dec 16, 2000 | 03:26 PM
Vader's Avatar
Neo,
I get all eight from the top, and the V-8 has all the options and emissions plumbing in place. I use a plug socket and box/open end wrench on the flats of the plug socket to get the "difficult" ones loose, then spin them out by hand. (This is one of the places that really makes me appreciate Never-Seez.)
It helps to be 6'4" and have arms like an orangutan, too. The most difficult is certainly #8, but it can be done. Access from the bottom is easier on some of the plugs, but it takes longer to raise the vehicle than contort into the engine bay, so I always just take the extra time and fight it out.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
