Alright, now i'm starting to get mad...................
Old Dec 17, 2000 | 09:53 AM
AcSeb's Avatar
Ok, hopefully somebody knows what to do here. A couple of weeks ago when I was leaving work, I step into my car, put the key in the ignition, and turn it. It's not turning like usual, it's just swinging around in circles like theres no resistance in the lock cylinder. I had to have the car towed home and I finally got out in the freezing cold to change the lock cylinder. I just got done changing it this morning, I put the key in, and the same thing happens. Now my dad thinks that it's some kind of a bar that the lock cylinder turns that goes down to some wires or something like that. Does anybody else have a clue what this could be?
**FOR SALE***89 Camaro RS 2.8 V6 auto
Exterior: White Interior: Black
T-tops, power-windows, locks, hatch.
Also, the new owner of the MeanYellowZ
Old Dec 17, 2000 | 10:11 AM
Vader's Avatar
AcSeb,
Your upper column should look something like this:
The rack gear that engages the pinion on the end of the lock cylinder can be worn, or broken farther down in the column (like mine did). You could also have a disconnected linkage rod at the upper end of the rack or at the switch itself.
Any of the above will require disassembly of the columndown to the bowl, so plan to spend the better part of the afternoon.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 17, 2000 | 10:16 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Doh.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited December 17, 2000).]
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
