need help - what heads should i go with?
Old Nov 6, 2003 | 04:47 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
im looking for a decent pair of heads for around $500. nothing crazy, nothing too mild. preferrably with as little required valvetrain upgrades too...id like to get a new roller cam that matches the new heads to suppliment the new chambers and get some more power out of the upgrade. and maybe a little muscle car sounding exhaust .
right now i have a carbed L98, everything is stock. what do you guys suggest?
Old Nov 6, 2003 | 06:11 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
GM L31 Vortec's. $519 + a matcing intake manifold $150.
or you could go for the Vortec's with upgraded vavle springs, and the proper machining for higher lift cams (up to .550) $739
either will make a proven 40 more horsepower.
since you already run a carburator, it should be pretty straight foreward.
Old Nov 6, 2003 | 06:52 PM
Engine: carbed L98
40fwhp or 40rwhp?
and do i need to upgrade any of the valvetrain? or should i upgrade anything? what cam shafts go good with those heads?
Old Nov 6, 2003 | 07:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: need help - what heads should i go with?
Originally posted by Trans_AM_88
... and maybe a little muscle car sounding exhaust
Uhhh, what do you have for exhaust now???
Old Nov 6, 2003 | 07:08 PM
Engine: carbed L98
Re: Re: need help - what heads should i go with?
well i was talkin about that muscle car pop pop rumble kinda sound from the long exhaust lift ( maybe not )...but i have stock headers, cat and hooker cat back. im getting hedman headers and y pipe though, and no cat.
Old Nov 6, 2003 | 07:11 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I had the original heads (083s) redone for $400.
That included milling off .005", new larger (2.02 and 1.6) valves, screw in studs, guide plates, large dia dual springs, bowl hogged and ported, and necessary machining for a .575 lift cam (using 1.6 rockers).
IMHO, the 083 heads have some real potential.
Old Nov 6, 2003 | 07:15 PM
Engine: carbed L98
do you have any numbers to back it up? dynos of your car or someone else whos done the same?
Old Nov 7, 2003 | 02:08 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Wish I had some flow-bench data, but I don't. My 1/4 mile times would not help much either since I did all my mods at the same time.
There's a couple of guys on this site that have documented their results working with stock heads. You'll have to do a search.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
