what motor is this
Old Dec 17, 2000 | 04:38 PM
82camarov6's Avatar
what motor is this
what year is this motor
heads-14022601
back of motor-k 14010203 it is a 5.0L
front of block-k0710T9K CF1219501
thanks
Old Dec 17, 2000 | 05:40 PM
ede's Avatar
ede
go to www.mortec.com
ICON Motorsports
1st & 3rd
Old Dec 17, 2000 | 06:52 PM
Vader's Avatar
82,
On the read ledge of the block, right above/right from where you found the casting number should be a date code. Usually they are four digits, like 1084 (October 1984). Some older castings use the clock dial method, which is a round indicator with a pointer aimed at the appropriate numbers for month and year.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 17, 2000 | 09:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Casting number 14010203 is 80-85 305 however I can't find T9K in any block codes for those years.
CF1219501 should be the end of the vehicles serial number but there's one to many numbers on the end. The C = 1982
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
