What is the cam specs on a 92 L98 cam?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Does anyone know the cam specs on the stock 92 L98 cam in the camaros?
I was wanting to know what kind of lift and duration it has. Also what are the stock springs rated for?
thanks.
thanks.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
According to what's on the Tech Data section of this site:
92 L98:
Lift: .413 / .428
Duration: 202/207
114.5 * Lobe Separation
92 L98:
Lift: .413 / .428
Duration: 202/207
Car: Camaro
Engine: Carbed L98
Transmission: TH350
92 L98:
Lift: .413 / .428
Duration: 202/207
92 L98:
Lift: .413 / .428
Duration: 202/207
I wonder what the springs a rated for.
oh yeah, thanks.
I imagine the springs could probably handle close to a .500 lift cam unless they're really weak....
Yeah, that is a VERY small cam. But then that motor only puts out like 245 hp stock, which isn't a heck of a lot for a 350.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
and given how old they are... they are really weak.
upgrade the springs if you upgrade the cam... cheap insurance.......
Car: Camaro
Engine: Carbed L98
Transmission: TH350
yeah, I ran across a guy that will replace the studs with screw in type. he will also replace the springs form. I figure it would be safer.
What would be the max lift with 1.250 springs with out machining the head? I heard something about the retainers or something hitting or binding if I have too much lift and didnt maching the heads?
