Head work
Head work
I´m going to port my TFS G1, and I have the
heads at home now. I´m havin problems with
a flat bar tool taking off the valves. These
springs are big but I think I`m compressing them enough, the problem is that the valve
follows down with the spring and I can`t
take off the keepers. Any ideas?
Also , do you know the torque for the head bolts for these heads?
Ben
Ben
a C type compressor is much better and you won't have that problem. the head bolts torque to 65 foot pounds
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
Car: 4
Engine: 6
Transmission: 5
Typical. The keepers are sort of stuck in the retainers.
Set the heads on a flat soft (like plywood) surface, put about a 3/4" socket on each of the retainers, and give them a good whack. If you whap them hard enough all the parts will just fly off. I know people who never even use a spring compressor for head tear down, but rather always do it this way exclusively. Sometimes even I do.
I hate work, I'm always looking for ways to make the work do itself. Usually it will with just a little application of brain power.
Thanks guys, I`ll make it in someway. I really hate to buy a compressor.... and is
really hard with the flat bar tool but I
don`t think I dare to solve it with the
FORD tool(hammer)
Ben
FORD tool(hammer)
Ben
Car: yep
Engine: uhuh
Transmission: sure does
I wouldn't hit the spring retainers with a hammer while the head was laying on the bench
I would be worried about slightly bending those nice valves. It is easily done.
I would do it the right way, with a compressor. You can also buy a small screw type spring compressor from pep-boys or another auto parts for pretty cheap.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Yes, an old screw compressor I had forgotten
in the garage did it.
I´m happy the valve guides were OK
The seals were bad but I`d change them anyway,those white teflon seals were pretty
bad.
I have the 1.447 double springs from TFS,
Which seals should buy?
Thanks.
Ben
bad.
Thanks.
Ben
