strange bump while driving
Old Dec 20, 2000 | 12:49 PM
84ZCam's Avatar
the other night i was coming home from work and merging onto the expressway and saw an accident that had happened up in front of me. i got on the brakes immediately and locked the wheels pretty good (just put new brake pads on the night before and wasn't quite used to them yet). i slid for a bit but was lucky enough to keep it under control and avoid any other cars.
as i was driving away i noticed a slight "bump" in the right front. felt and sounded exactly like a flat. i immideately figured i must have blown the tire, but when i got home it read about 32 psi. this really shocked me because as i was checking the pressure i also heard a hissing sound.
next morning i got up and the tire read about 34 psi (cold morning). so i jumped in and cruised around the block to see if the bump was still around. just as strong as the night before it was still there. i inspected the tire as well as i could while still on the car and can't see anything wrong with it. i'm puzzled!!! is there a chance i could have just worn a flat spot in the tire? i really can't figure this out out. anyone have any ideas or things i should start checking out???
Old Dec 20, 2000 | 01:33 PM
gmanuel's Avatar
I would be enclined to suggest that you have a flat spot and/or a belt broke inside the tire. I have experienced my car vibrating at speeds over 50mph and it was a tire
Infested
May 22, 2018 11:56 PM
red90IROCls1
Aug 25, 2015 06:56 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 9, 2015 01:15 PM
