Interesting, car runs w/o fuel pump relay?
Old Dec 18, 2000 | 08:33 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Maybe I'm not 100% sure, but I feel pretty confident ... that the relay that was disconnected is the fuel pump relay. I remember Pablo and Jester helping me out one time with it. Regardless, I've been starting the car, pretty much, every weekend ... and yesterday, I found this relay disconnected ....
.... and it still ran fine ... why?
(Check the sig for car info)
The Camaro Shrine
'88 Camaro IROC-Z 350 TPI
'98 Grand Prix GTP 3.8L SC
"Yea, though I walk through the valley of rice,
I shall fear no Turbo; for Torque art with me."
- Cullan Hooley
Old Dec 18, 2000 | 07:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Because once you build up oil pressure, there is a parallel path for voltage through the oil pressure switch, to the fuel pump...
Or someone has it hot wired....
Old Dec 18, 2000 | 08:06 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
hmm that relay goes to the fuel pump to? on my car i have one that appears to be the same thing, same wires and stuff but i know i have no fuel pump, and that my fan is also controlled by it!
steve
Old Dec 18, 2000 | 08:07 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
that is excactly what is happenig and if you had a pump that did not hold fuel presure it would crank for a while before starting
Old Dec 18, 2000 | 08:09 PM
Engine: ls1, LB9
also if you wish to disconect the fuel pump you would need to go just ahead of the tank and disconect the harness this may also cause your gage to read full though
Old Dec 18, 2000 | 09:23 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Yes, that's whats been happening. If I wait a few days and crank, it takes a while for it to crank up. Just freaked me out a little when I noticed that thing disconnected!
Old Dec 20, 2000 | 09:55 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Okay, I waited a couple of days to start it again. The relay is plugged in now. As soon as I turn the ignition on, I can hear the fuel pump kick in of which I don't remember hearing for a while. It started pretty much right away .. so yes, it is the fuel pump relay.
[This message has been edited by Allan (edited December 20, 2000).]
Old Dec 20, 2000 | 07:56 PM
Engine: ls1, LB9
sounds like every thing is working the way it should
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
