Undercoating options??
Old Nov 12, 2003 | 06:48 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I want to get subframe connectors and get the underside of the car undercoated when I have them installed. Are there any different options or methods of undercoating that I should ask the shop about when I go to get this all done? Thanks.
Old Nov 12, 2003 | 07:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
What type of undercoating are you considering? Most places just use the same stuff you can buy and use yourself. If you want somthing that will last you might consider having the underside of your car Rhyno lined in a nice color that matches your car.
Old Nov 13, 2003 | 07:46 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
If you have any rust, look at POR-15. My car looked like they shipped it with a bar metal floor. The whole underside was covered in surface rust. I hit it with a wire brush, then coated it with two coats of POR-15 Semi Gloss Black. It looks Great!! I am proud to tell people to look under it, or to have it put on a rack now. I used 1 pint to do the whole thing, just be careful, this stuff does not come off of you for a long time. I had black dots on my arms, and a couple Black spots in my hair for a while.
They have a lot of good products, see my thread on their header coatings elsewhere, I think their website is www.por15.com
Old Nov 15, 2003 | 11:12 AM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
What's the difference in semi-gloss black and just the regular black? is the regular flat black? im curious because im going to be doing my engine compartment and underside soon and i don't think i want them flat black.
Old Nov 15, 2003 | 01:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
You probably DO want them flat black. An example from my own experiance would be my 76 C10. I painted the engine bay in what you might consider a semi gloss, had a bit more shine then normal. If you use the black like I did it shows all the underhood imperfections and they stick out like a sore thumb, making it look horrible. I re-painted in a flat black and the engine compartment looks clean now, nothing to really catch the eye. With my bird I did the same thing with the engine compartment in flat but the wheel well areas I use a gloss black, looks sharp.
Old Nov 15, 2003 | 09:47 PM
Car: '86 IROC
Anyone got n e pics of what this might look like? either flat or semi-gloss
Old Nov 24, 2003 | 08:01 PM
jdrafke's Avatar
hey guys im getting ready for the winter up here in chicago and want to undercoat my car. Im in shop class at high school and im wondering how hard/long this thing would take to undercoat the bottom side of the car(floorpans,frame etc.)Also, do u have to buy their metal ready and marine clean products to prep the car before hand. if not, what cheapier ways are there to prep it. thanks
Old Nov 25, 2003 | 07:40 AM
Car: 1971 Camaro
Engine: 427
Mine was just rust, no grease or anything under it. I just went over it with a wire brush, and then painted it. I did one coat in about 1 hr. With the car on jackstands. I let it cure for 24 hrs. And did a second coat. If yours has grease on it or isn't all rusty, I would use the metal prep and marine clean. They have to be diluted so they both go a long way.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
loud91rs
Oct 5, 2015 10:05 PM
