L98 Power Problem.....
Car: 2008 Jeep Wrangler Unlimited
I noticed over the past that my car dosent seem to pull as solid as it used to, another symptom is that when i lets say push the gas pedal 3 inches down it used to pull, now it just makes the car loud like its working, but dosent pull? Any ideas???
1991 Z28 Camaro L98 5.7L
http://www.IROC-Z.org/3rdgen/BandetZ28-resized.jpg
http://www.IROC-Z.org/3rdgen/BandetZ28-2-resized.jpg
Sounds like something behind the engine to me. Tranny related probably
Clem
The world is full of stupid people...and I am no exception.
'83 Z28 5 speed (regrettably with T-tops)
'83 Z28 No T-tops (regrettably automatic)
Clem
Kamaro,
How is the idle quality? I had a similar problem on a 305TPI, and a mild "miss" in the idle, that progressivly got worse over time. After going over the ignition and ECM control system with a fine-toothed comb more than once, I pulled the injectors and shipped them off to Cruzin' Performance for cleaning and flow matching. What a difference it made. I felt like a kid with a new car.
It is then that I learned after some detailed research that the resistance of the injector operating coils really means nothing. The only accurate way to test injectors is to remove and flow test them. The ohmmeter check is only valid for testing the coils in a go/no-go condition, and means nothing to injector flow.
Just a possibility.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Just a possibility.
Later,
Vader
Vader, sometimes while idleing awhile it will kinda jump and struggle, then will be fine, and do it again shortly after but i dont have this problem much.
sailtexas186548
Aug 24, 2015 10:11 PM
