Is my car possessed?
Old Nov 13, 2003 | 03:35 PM
H-BOMB's Avatar
Car: 89 GTA
hello,
Ok I have a 89 L98, every couple of days all my lights and my stereo will turn off for a couple of seconds but they quickly come back on. it last happened last night, i was on the freeway and all my lights and stereo went off for a couple of seconds but they quickly came back on. It's like the battery gets disconnected because all the presets are lost on my stereo everytime it happens.
HELP!!
Old Nov 13, 2003 | 03:53 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Probabally a bad connection on the battery. Check your grounds for any corrosion.
Old Nov 13, 2003 | 06:52 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
YES YES IT IS.... i think you need a priest....for the exorcism
anyways check your connections
Old Nov 13, 2003 | 07:09 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Would the engine shut off if the car lost power? Or can the engine run for awhile without a battery?
Old Nov 13, 2003 | 07:35 PM
H-BOMB's Avatar
Car: 89 GTA
I will check connections when i get a chance, my engine keeps running when it happens...I'm not sure if engine dies when battery is disconnected
Old Nov 13, 2003 | 10:03 PM
M84Z28's Avatar
Car: Black 1984 Chevrolet Camaro Z28
Engine: LG4 305
From what i understand the engine would still stay running without the battery. The main purpose of the battery is the start the car. While the car is running the alternator runs the car and charges the battery back up. Although someone correct me if im wrong.
Old Nov 13, 2003 | 10:56 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
if the engine dies when u unhook the battery cables, it means your alternator has took a crap on you. M84 has the right idea..
check connections to the alternator, striped wire...
are there any other symptons?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
