hydraullic block into roller block
Old Nov 13, 2003 | 09:40 PM
anubiscougar's Avatar
Ok.. from what i understand, a roller cam cannot fit in a block made for a hydraullic block. I"m looking into getting a 400ci sbc, now.. they didn't come w/ roller cams, so.. i'm sol there. However, i have been told you can have them machined to take roller cams.
Is this true and is it expensive, or just about the same as boring a block out?
Also, what is really the difference & why can't a roller cam fit into a hydraullic cam's place?
Old Nov 13, 2003 | 09:50 PM
MCas7's Avatar
You CAN put a roller cam into a block that didn't come with one. You just have to get roller lifters that have the little bars that keep them from twisting. Roller blocks have these brackets that bolt into the lifter vally to hold the roller lifters in place, that is really the only difference.
Old Nov 13, 2003 | 09:51 PM
85TransAm406's Avatar
Car: 1985 Trans Am
The roller cam fits the same as a stock cam. You have to get retrofit hydraulic roller lifters because the lifter bores are different, and also get different length pushrods.
Old Nov 13, 2003 | 09:55 PM
how much harder is it to find that stuff, and is there any performance decrease?
Lead me to any good stuff plz?
Old Nov 13, 2003 | 09:57 PM
MCas7's Avatar
Summit will have pretty much everything you need to get it all together.
Old Nov 13, 2003 | 10:08 PM
alright, found the rollers.
how different of size pushrods would i need? or does it depend on my cam?/heads/...setup..
Old Nov 13, 2003 | 10:15 PM
MCas7's Avatar
Unfortunatley, I'm not positive about the different pushrod lengths. What you might have to do is buy a pushrod lenth checker (sold in summit) and check them that way.
Old Nov 13, 2003 | 10:20 PM
Car: 1985 Trans Am
On the pushrods, the length checker is the ideal way to go, though comp cams will sell you "roller retrofit pushrods" which will be pretty close. I won't risk that, i've had my block/heads decked and running all aftermarket valvetrain.
Old Nov 13, 2003 | 10:42 PM
going w/ a crane cam, they ahve about the same thing? gonna look on their site tomorrow morning... erm, afternoon... erm.. saturday, going paintballing all tomorrow.
Old Nov 13, 2003 | 10:44 PM
ohya, so what you guys are saying is.. basically, get it together somewhat, and then check it out?
crappa.
Old Nov 13, 2003 | 10:45 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
do you need a cam retention thing too? so it doesn't walk? or will a good old cam button work?
Old Nov 13, 2003 | 11:05 PM
Car: 1985 Trans Am
Cam button will work, but if you have a stamped steel timing cover it will deflect too much. My edelbrock has an adjustable stop that threads through it that pushes against the cover where the cam button is, to prevent that from happening.
Old Nov 14, 2003 | 10:01 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I did the whole process to my non-roller block. It is expencive, no doubt, but I liked it in the end. I found a CompCams "K-kit" which has almost everything! It came with the roller cam, roller lifters, correct valve springs, retainers, locks, valve stems seals, timing chain. If you have the means to buy the K-kit, the retrofit is simple and straight forward, and are about $750 for the kit. Just expect to have $1000 into just having a roller cam.
You will need to get a pushrod length checker, Like this then get new pushrod to keep your geometry correct
Also they make specific roller cam buttons, which you should pick up, Like this for $10
Old Nov 14, 2003 | 10:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Really?
I've been building roller motors for a long time, a couple of decades before the factory sodomized the concept; never really had any trouble with them.
I personally prefer the really high-dollar Comp roller thrust bearing cam button; it's about $15.
Most hydraulic roller lifters are .400" talller than flat-tappet ones, so you typically need .400" shorter push rods. But the only way to get it right is to measure them with an adjustable push rod.
Old Nov 14, 2003 | 10:26 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
I used the roller cam button, like you talked about and I put a link to, with a stamped chrome timing chain cover and after a while i could see it bulging where the button was, so i went to a better timing chain cover. Get a 3 piece so you can do a cam swap without removing the timing chaing cover from the oil pan!
Old Nov 14, 2003 | 10:29 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
This swap is pretty common. I think with the retrofit parts youd be fine...
You paintball?
I have an 02 vert feed autococker and a nice nasty impulse for sale...wink wink
Old Nov 14, 2003 | 11:08 AM
Car: 1985 Trans Am
I had the same thing happen, now I use one of the cast aluminum ones. I know people who haven't had problems with the stamped cover, but I checked cam endplay after my friend pulled his motor, it was twice maximum specs. When I put it together it was on the tight side of minumim.
Old Nov 14, 2003 | 11:20 AM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
SweetS10V8, i just happened to notice that you're studying at UNO. is it still the same sh!thole it was? i used to live in CP 18.
Old Nov 14, 2003 | 12:20 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
The school is nice, but you used the right term, the town is a **** hole, I almost didnt come to the school bc of town, i was having serious 2nd thoughts. I have a serial rapist on my street apparently(1 mile long), people get shot like no big deal.
I like school, I wouldnt leave my wife alone anywhere in town.
Here is the description of my home town:
Midland, Michigan, home of the Dow Chemical Company and Dow Corning Corporation. Located 15 miles from Lake Huron and 135 miles north of Detroit, Midland is a middle-class suburban town whose inhabitants feel comfortable leaving their cars unlocked and where students love to roam during their free time.
hmmm.....from door unlocked to serial rapist and murders. Seriously in the 25 years I lived in Midland, I can remember 1 shooting!!!
Sorry to go off topic...back to the regularly scheduled programing!
Old Nov 14, 2003 | 12:26 PM
Engine: V8
damn...so you lock your house doors and take your keys out of the car and stuff too huh? city folk are weird, i could sit my car in an alley, by a group of kids that looked like trouble makers, leave it running with the door open, come back an hour later and it'd be in the same spot...probably out of gas with a dead battery, but in the same spot, untouched
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Jorlain
Oct 8, 2015 01:57 AM
anesthes
Sep 18, 2015 12:34 PM
RyanJB
Sep 14, 2015 03:39 PM
