2 vs. 4 bolt
Old Nov 11, 2003 | 02:03 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
2 vs. 4 bolt
I havent ever seen this debated since I have been a member so here it is. For those of you running between 400 to 500 HP/TQ stroker motors, whats your opinion/expeirence about running a two bolt main vs. a four bolt. I am stroking the motor in my Z and want to use my stock block because its a roller block. I have an older block (4 bolt) but do not want to retrofit it for a roller cam, which is a must for my preference. I guess I can splay my stock block..... but like I said, Opinion/experirnce's please.
Old Nov 11, 2003 | 03:22 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
splayed mains are stronger then factory 4 bolts because they are off set and not in a straight line like the factory blocks.
Old Nov 11, 2003 | 03:27 PM
ede's Avatar
ede
i wouldn't worry too much about hom many bolts hold the main caps on. i worry more about blueprinting the crank and rods along with useing good rod bolts
Old Nov 11, 2003 | 04:48 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
what he said
Old Nov 11, 2003 | 10:30 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
my buddy is running a 383 2 bolt, he used an ARP stud kit, no problems
Old Nov 12, 2003 | 01:56 PM
MYBLUZ's Avatar
Engine: Blown 383
I was planning on studding the bottom regardless if I splay it or not. I would have to agree that machining and balancing the bottom end is more critical. I would still like to see some more opinions on this subject. Thanks.
Old Nov 12, 2003 | 11:12 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Many years ago the webbing around the mains were thin and weak and would not handle a 4 bolt mains straight in. So they angled them into a stronger part of the block. and that cured the problem and they still use that today. Now if you have a newer
block the webbing issue has been fixed and when the block machining is done properly, you shouldn't have any problems with a standard 4 bolt main arrangement.
Old Nov 14, 2003 | 03:18 PM
MYBLUZ's Avatar
Engine: Blown 383
You guys HAVE to see this [url]http://www.corral.net/forums/showthread.php?s=&threadid=387871
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
