My Car Is Dead! Neep Help
Old Dec 21, 2000 | 12:53 PM
1989RedGTA's Avatar
I get into the car, no power to anything, i turn the key, nothing happens. Interior lights/locks everything is dead. Just like it has no battery. I already replaced the battery and the Alt is only a year old. What else can be wrong with this car? Everything is totally dead any ideas and where can i find the problem???? This has happened before. Usually the car will start right back up, ill drive it for like 10 min turn off the car and come back in 5 min to turn it back on and its dead. It cant possibly be the battery, i replaced it twice already. Is there a thing called a voltage regulator on the car, if so can that be it and where can i find it...
Old Dec 21, 2000 | 02:20 PM
hdtripp's Avatar
Car: 89 Formula
Engine: 5.0L tpi
Transmission: 7R400
Have you checked your battery cables to make sure they are tight and have no corrosion? It sounds like the problem is there somewhere.
H.D. Tripp-89FormulaWS6 w/5.0L TPI, Street & Performance Chip
Old Dec 21, 2000 | 02:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd say before checking the battery cables, use a voltmeter at the cig lighter. Then use a voltmeter at the battery. If they don't match then you know it's the battery cables; rather than wiggle them/tighten them, and the car works fine- you'll never know for sure if that's what fixed it. Know what I mean?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 21, 2000 | 03:15 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
How long does it take for the bat to die?
Have the alternator tested for reverse leakgge across the diodes.
Old Dec 21, 2000 | 04:07 PM
jrr's Avatar
jrr
Man, you have a SERIOUS short somewhere. If the battery is being drained even while the engine is off, then find out what things are always "hot".
There aren't too many things that always have juice going to them. The alternator, the battery cables themselves, the fuse box...somewhere there's a wire with the insulation worn off and touching bare metal.
Old Dec 21, 2000 | 04:36 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Check for a loose ground somewhere.....that's most likely your problem!
Old Dec 21, 2000 | 04:49 PM
CamaroZ_85's Avatar
did the fusible link blow?
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
