Anyone know the stock 1/4 for a 1986 IROC Camaro 305 TPI?
Old Dec 22, 2000 | 02:01 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Hey! just wondering if anyone knew what the 1/4 mile times, and trap speed for my car when it was new. i know im not running anywhere near stock anymore (old everything)
thanks!
Old Dec 22, 2000 | 02:27 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Sadly the '86 TPI was hobbled with a poor camshaft. So, you may not like to hear about how the car was originally a 16.1 second, 86 MPH performer.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Dec 22, 2000 | 02:34 PM
Christos's Avatar
figures. my two friends own these two cars:
1999 Volkswagen Golf GTI GLX 2.8 L SOHC V-6 2880 lbs 174 bhp @ 5800 rpm 181 lb/ft @ 3200 rpm 6.8 sec. 15.3 sec. @ 92.7
1999 Acura Integra GS-R 1.8 L DOHC VTEC In-line 4 2620 lbs 170 bhp @ 7600 rpm 128 lb/ft @ 6200 rpm 7.2 sec. 15.6 sec. @ 91.1
All of a sudden, V8's look like really stupid engines to own. granted, we have come a long way in 14 years. but still...
I can see why muscle cars arn't as vogue as they used to be. with a new civic able to hold almost as good, and a new integra being able to beat a older camaro stock...
no replacement for displacement my *** . true, if i took my 2,700 dollar car, and had a budget of a new car (18-22 grand) i could really make it fast, but uh, you can't quite take out a new-car loan for that much, and drop it in a older car. no bank would allow that.
Sad thing is, the integra owner used to own a 1988 z/28.
Hmm. there needs to be a bank that will loan out more money for a personal loan. (granted, how much you make, and credit history count for some, but even then, a personal loan isn't going to be much. certainly not enough for a crate zz4, and all of the installation goodies)
thanks for the specs! i figured it was around there myself. couldnt seem to find them anywhere!
Old Dec 22, 2000 | 02:44 PM
ws6transam's Avatar
Look at my SIG.
Does my little 305 look slow?
Did you know I spent only $850 on the engine, and $650 on the exhaust? I also spent $22 on my induction system.
I have a lot of extra speed parts on the car, but they are there because of my intent to step up to a 450 HP engine.
So, if you want to go fast, do this:
take your Z28, and let me port the plenum & intake. Add a cam. Add a real exhaust system. Tune up the ignition system.
You'll now be in the 14's and mid-90's at the track. Your total investment will be the cost of your car plus about $1000 to $1500.
The simple physics of rear wheel drive are in YOUR favor! You are simply the victim of mid-eighties emissions rules. In the year 2000 there are many, many new tools at your disposal that are both effective, inexpensive, and relatively clean with regards to emissions.
I don't think it's fair to compare a new $18000 car to your Camaro as far as performance. How about comparing a new $18000 V6 Camaro to your friends car? The V6 puts out more power than your present V8 due to technology advancements. The 3800 V6 is a true 210 HP engine that turns low 15's in the quarter mile. Now, compare your V8 to a 1965 283. That little '65 283 was a 17 second engine. Even the '57 Corvette with dual quads was only a 15 second car, IIRC. Perspective.
Good luck.
Daniel Burk
[This message has been edited by ws6transam (edited December 22, 2000).]
Old Dec 22, 2000 | 03:41 PM
Christos's Avatar
Hey! thats cool to know. I know my car was the emissions BS model, with the cat and header hole/fuel tank air and charcoal canaster things, and peanut cam. but i never thought of it like that.
thanks for the ideas and suggestions!
Old Feb 2, 2013 | 07:44 PM
Redchevy808's Avatar
Car: 1992 camaro rs
Engine: 92 350ci carbed
Transmission: 700r
Axle/Gears: Stock 10 bolt 2:73 gears 😭
Re: Anyone know the stock 1/4 for a 1986 IROC Camaro 305 TPI?
Lol peanut cam, i ran a low 15 with my rs, just a mostly stock 350(truck motor I might add lol) stock heads ported, and exhaust. Still had the cruddy 2:73 gears too, get a good cam and you should be happy
Steven 86IROC-Z
May 24, 2026 04:52 AM
jaridjohn
Jul 8, 2024 03:49 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
