Car power lost no ecm codes.
Old Dec 22, 2000 | 08:34 AM
LT90RS's Avatar
Ok Guys,
My car 90 RS with TBI has lost bottom end power.It will not idle half the time.
I have replaced the ECM,plugs,Disturbuter,cap,rotor button,O2 sensor,fuel filter,and cleaned the IAC.
Ok what gives? It is not giving any codes. I am replacing the coil today. Any ideas?
Thanks for your help.
Larry Taylor
90RS 305TBI\5-speed
Fastchip
Open Air Cleaner
1.5 Roller Rockers
Lakewood LCA & Panhard,10 Bolt Posi-Disk Rearend 3.42's
KYB all around
Energy Supension front end kit
36/24 Sway bars
Dual Fans
In the works-
LT-1 Cam
SSM subframe connectors
Old Dec 22, 2000 | 11:11 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
How is your fuel pressure?
Old Dec 22, 2000 | 12:35 PM
Jason M 91Z's Avatar
Pull your 02 and take the car for a spin to see if it feels better. It will sound like it has a big exhaust leak, so don't be alarmed. If it feels better, your cat is plugged, and that doesn't take much with your stock 2 1/4" POS cat. Other than that, check ignition timing and if you have access to a scan tool, determine what your knock counts are. Good luck.
-Jason M. 1991 Camaro Z28
"Shampoo is better, I go on first and clean the hair."
Old Dec 22, 2000 | 12:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Try a compression check next. Cheaper than swapping parts.
Old Dec 22, 2000 | 01:41 PM
Ski89Z28's Avatar
I had a simular problem and I replaced the ignition control module in the distributor and that fixed it.
I was told it won't throw any codes if it is going bad, optimun word GOING. If the idling problem seems to get worse as the engine heats up then it is probably the module.
Good Luck!
89 IROC 350 Auto
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
14.01 @ 97.0mph with 2.77's gears and a bad ignition control module!
And Free mods.
Old Dec 22, 2000 | 03:33 PM
ede's Avatar
ede
i was thinking clogged cat. compression test would tell you a lot too.
ICON Motorsports
1st & 3rd
Old Dec 22, 2000 | 04:10 PM
LT90RS's Avatar
Cat is Hollow guys. Changed the coil.Changed IAC with No effect. Will check gap on plugs and do a compression check.May change plug wires too. Oh well I will up date in a day or so.
Thanks guys.
90RS 305TBI\5-speed
Fastchip
Open Air Cleaner
1.5 Roller Rockers
KYB all around
36/24 Sway bars
Dual Fans
In the works-
LT-1 Cam
Old Dec 24, 2000 | 02:22 PM
LT90RS's Avatar
BTTT
90RS 305TBI\5-speed
Fastchip
Open Air Cleaner
1.5 Roller Rockers
KYB all around
36/24 Sway bars
Dual Fans
In the works-
LT-1 Cam
BlueIroc-Z
Jun 9, 2019 03:22 AM
mizz0313
Aug 12, 2015 06:45 AM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
antares57
Aug 6, 2015 07:47 AM
