SH*T I BROKE THE SPEEDO NEEDLE OFF
Old Dec 25, 2000 | 11:43 AM
matty350TPI's Avatar
Can I super glue it back on? The metal snaped in a way that I can fit it directly back on where it is supposed to be. Its a brand ne cluster...**** I WANT TO use it...it cost me 115 bucks ****.....HELP PLEASE HELP me with ideas....I have a 115 mph clauster can I switch out anything into the new one to fix it?
1988 IROC-Z T-Top
350 Crate engine
370ft. lb Torque STOCK
5speed Centerforce clutch
Old Dec 25, 2000 | 12:25 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
If it's a stock cluster and the 88's are like the older ones the needle just presses down on the shaft. If you can get another needle at the junkyard you should be able to remove the broken part by pulling it off and then just push the new one on (make sure the needle points to the right spot).
Z's r Best
Old Dec 25, 2000 | 12:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the needle has come off, you may need to have the speedo recalibrated if you wish it to read correctly.
JamesC
Old Dec 25, 2000 | 07:43 PM
Blade's Avatar
Just put the needle on with superglue. I did it to my 85 and it worked fine. My needle was a hair above the first line on the dial when resting.
Old Dec 25, 2000 | 10:48 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
It sounds to me like you actually broke the metal shaft that the needle presses onto. That would suck. you could try the super glue, but I don't think it will last very long. If that is not the case and you just broke the plastic needle itself, super glue will work, but may look bad, in which case you can take the needle from another cluster. If you just pulled the needle off, press it back on, and remember that it will be off. For a reference, I read in a post a while back that 1000 rpm's into the speedo should make it read 60 MPH.
Good Luck!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
