Setting timing right now-pls help asap!
Old Dec 26, 2000 | 11:47 AM
SGT SWEETPANTS's Avatar
I know I need to disconnect a plug on the distributer, but I have no idea which one. There was a picture posted awhile ago but it was for a tpi setup. Please help, the car is running and waiting for me to return.
Old Dec 26, 2000 | 11:48 AM
Forgot to add my sig to help you out-it is an LG4.
'86 IROC-Z
305 LG-4, T-5
T-Tops
50k Original Miles
K&N Air Filter
Stage I Chip
KYB Shocks/Struts
Centerforce Dual Friction
Old Dec 26, 2000 | 11:53 AM
ede's Avatar
ede
i think it's tan wire white stripe. should be in a loom over or near the blower box. it's a single wire and has a connection you unplug. if the timeings been set before it may be hanging out.
ICON Motorsports
1st & 3rd
Old Dec 26, 2000 | 12:02 PM
Thanks, but I finally found the right one. It is a large 4 wire pug that hangs way down behind the distributer.
'86 IROC-Z
305 LG-4, T-5
T-Tops
50k Original Miles
K&N Air Filter
Stage I Chip
KYB Shocks/Struts
Old Dec 26, 2000 | 04:06 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
That doesn't sound like the correct one to me; sure hope you're right.
It's usually a tan wire with a black stripe with a WeatherPak connector.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Dec 26, 2000 | 04:31 PM
Blade's Avatar
Ede & Jake let's not forget he has an LG4. He's absolutely right about the 4 wire connector. Dont pass out info if you're not at least 99% sure it's correct
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Dec 26, 2000 | 07:47 PM
ede's Avatar
ede
yeah blade you're right, but i was at least 99% sure it was. guess none of us know everything. never had a lg4 so i wouldn't know for sure and i doubt if any of us look in a manual for info before we post. but if we'd look in a manual first we'd have a lot less post. actually all the rpo engine codes don't mean much to me, i can't keep up on them. only ones i remeber are l98 and l79.
ICON Motorsports
1st & 3rd
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
dutch930
Sep 11, 2015 06:58 AM
