streetable cam
Car: 83 Camaro
Transmission: th350
streetable cam
ok....im buying a new 350 soon here and i need to know whether i should pay the extrra 150 and get a hydrolic roller cam...also....depending on your choicewhat kind of cam should i throw in there. i talked ot the place and if i supply the cam they will put it in and the warrenty will stay as long as the cam is new...any suggestions....i dont want anything too radical...but i want it to have slightly lumpy idle and mid to higher rpm range but more mid than high...
...i know im picky
edit...this motor will be carbed.,..9.5:1 compression, hyper pistons....cast crank....PM rods i think he said too
...i know im pickyedit...this motor will be carbed.,..9.5:1 compression, hyper pistons....cast crank....PM rods i think he said too
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
How much will this car be driven on the street? Do you have a manifold yet? Gearing/stall?
Car: 83 Camaro
Transmission: th350
ummm...this is for more of a weekend car ...its got 2600 stall....3.42's.....i just wanna be able to have a blast when im not in school...
