Anybody with ARP Head Studs?
Old Nov 23, 2003 | 02:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I picked up a set to use on my new 383 and was wondering if I should look out for anything? I know people use bolts in case of head removal in the engine bay, but since I will have enough room just in case I'm not really worried. I have used the ARP head bolts before with no problems, but this time I want to go with studs in case of adding a power adder in the future. I'll rest asure knowing that the seal is clamped tight.
Old Nov 23, 2003 | 03:18 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
use the ARP threda sealer on the threads that go into the block, and ARP moly lube on the end that the nut goes on
Old Nov 23, 2003 | 03:52 PM
ede's Avatar
ede
if you ever want to remove the heads with the engine in the car you'll find it very hard to do. buy a set of 12 point nuts if the studs didn't come with any, actually you only need a couple but i don't think you can buy just a few.
Old Nov 23, 2003 | 04:25 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You can buy the smaller head 12 pt nuts from ARP directly if you only need a few. I needed only 6 for spring clearance when I intalled my AFRs with larger springs. The ARP hardware is great quality, you'll never have to worry about head bolts breaking...
deracer
Apr 11, 2016 12:04 AM
z28guy134
Sep 1, 2015 11:50 PM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Aug 25, 2015 12:54 AM
