LT1 Oil pan Q?
Old Nov 20, 2003 | 03:39 PM
Drakar's Avatar
LT1 Oil pan Q?
The LT1 engine I picked up, when the taxi company towed it back to there shop before we got it, they dented the oil pan.
Looks like a sledge hit the bottom and push up on the middle. Should I try and fix that with reverse beating it out.
Or should I replace it.
If I have to replace it will any SBC oil pan work?
Old Nov 20, 2003 | 03:49 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If its a smooth dent with no cuts or sharp creases it should bend out okay. If you need to replace it any SBC passenger car (not from a Vette) one piece rear main seal pan will work.
Old Nov 20, 2003 | 06:38 PM
Vader's Avatar
Just a few thoughts/observations:
If the pan is dented more than ¼" it may interfere with the oil pump pickup, possibly restricting intake oil, or worse, it may have dislodged the pickup, allowing the pump to draw and pump air instead of oil.
If the engine came from a taxi company, it was probably in B-body. If that's the case, it would be a '94-'96 model. Those year B-car engines have either an oil level and/or oil conductivity sensor in the left side of the pan. There may be a problem with an altered oil level, or damage to the sensor.
If the engine came from a taxi (SEO vehicle) B-car, it is very possible that it isn't an LT1, but an L99. It is externally identical to the LT1, but is only 265 cubic inches. Check the casting and stamped engine codes very carefully before writing the check. Very few SEO vehicles (other than police) actually got the LT1, since most taxi companies wanted the smaller engine for better in-town fuel economy.
The sealing ledge at the timing cover on the LT1/LT4/L99 is slightly different than the "regular" SBC engines, so you may not be able to use any old oil pan. The tapped hole in the left side is also a difference.
This is going into an F-body, right?
Old Nov 20, 2003 | 06:45 PM
Vader's Avatar
Like this:
Old Nov 20, 2003 | 11:06 PM
Drakar's Avatar
Thx for the info Vader,
I have confirmed that it is a LT1 came out of a 96 buick roadmaster wagon (identical to my dads) also mechanic friend of ours saw it go into the fleet (shop next door) and I confirmed it via block, VIN, and RPO codes. For economy the converted to propane.
Yes going into an 85 Z original carb. (will do A/C delete, so no frame notching)
The dent looks like if you take a piece of paper and hold it up it kinda crinks around where your holding, same idea.
What options then LT1 oil pan only??
Old Nov 21, 2003 | 06:56 AM
Vader's Avatar
As long as the engine is out, I'd remove the pan and try to straighten it. It sounds like the dent is not so severe that it can't be repaired.
Since it's an LT1, you should have some very good flows on the iron heads. Slightly better than even the aluminum LT1 heads. Should make a nice powerplant in your car.
Old Nov 21, 2003 | 10:50 AM
Drakar's Avatar
Thanks for your help Vader.
I'll give it a shot at fixing it, I have plenty of time the engine is on a stand and I don't plan on it going in for maybe another month or two most likely Jan sometime. I do plan to port(minor) and polish(mostly) the heads, intake and TB and possible cam change.
Do you know how much lift the stock springs can take? or should I just change them out as well. I was going to change to most likely an F-body LT1 cam still mild but a little more then stock b-body cam.
Thanks again
Old Nov 21, 2003 | 12:33 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
If i where you, I'd look at getting the hotcam kit for your car.
Its a great cam, the kit is $500 but includes your whole drivetrain if I'm correct.
WyClef
Old Nov 21, 2003 | 01:07 PM
Ricktpi's Avatar
ede is right, the LT-1 oil pan is slightly different. It was late in the day & after reading electronic catalogs all day, the part #s start to look all the same. The B-body oil pans can be used, you just have plug the oil level sensor hole up with a M20x1.5 bolt & some epoxy. I used a 92 police engine with the B body oil pan & it fit the F body chassis no problem. I have also hammered out dented in oil pans with no problems as well. The LT-1 cam is not very impressive in the F body form either, the LT4 would be a better choice.
Old Nov 21, 2003 | 01:14 PM
Drakar's Avatar
I don't have the cash for the LT4 kit, I would like to go full LT4 sometime soon, but I was only looking for a cheap upgrade that wouldn't waste my springs, and most people say LT1 cams go for 50 bucks or so?
I guess it might not be worth the effort to put that cam in for so little gain.
Ill just do the swap and work, and then start the old saving pool for the LT4 kit, or a T-56 depending on if my T-5 breaks or not
Thanks guys
Old Nov 21, 2003 | 04:40 PM
Engine: peanut LB9
i'd save and get the LT4 hot cam kit. tryricing everything it comes with for that price anywhere anyd your goiung to be well over $500. the cam is about $140. (new)
Old Nov 21, 2003 | 05:04 PM
Vader's Avatar
What are you planning to do with the distributor?
Old Nov 21, 2003 | 05:05 PM
Drakar's Avatar
Im not sure I follow?
Old Nov 23, 2003 | 04:19 PM
Ricktpi's Avatar
I would imagine he's using the Optispark from teh LT1
Old Nov 23, 2003 | 04:37 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
oh no.... optispark
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
