are these good lifters?
Old Nov 23, 2003 | 04:23 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
hi,
i'm searching for some new lifters since i have seen, that my original ones are not so good than i thought they were.
is this a good replacement? does anybody know the seller? or is this stuff crap? he says thats's an original gm part, but it is so cheap
thanks!
nebu.
Old Nov 23, 2003 | 04:31 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Read the ad carefully. The seller states that the auction is for the composite lifter retainers. It also says they are a new GM Performance Part. It also says that is is designed after the Gen III small block, LS1. So, if you need lifters, you will not have them from him. I think you best bet would be to contact Comp Cams or Crane. Sure they make "performance" parts, but they will work and most likely be of higher quaility than you typical part store parts. Maybe even cheaper than the dealer. Just my $.02
Old Nov 23, 2003 | 04:39 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
ah ok, thanks. i have overseen it
i think i will buy some lifters from crane for about 180$. original lifters from the dealer in germany cost about 400$....
nebu.
Old Nov 23, 2003 | 06:58 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
nebu.
$400!!! That's insane!!! Go with the Crane...
beastin91rs
Oct 9, 2015 07:38 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
cstrobel65
Aug 15, 2015 10:19 AM
