Need help with the rear fuel pump relay! Need Help ASAP!
Old Nov 26, 2003 | 03:14 PM
CrazyGTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 350 v-8
Transmission: auto
Well I trace, and tested the relay in the fron of the car(89 gta-5.7) and it tested fine, but I'm trying to find the one in the rear? Is it above the rear end on the body? Does it have 3 wires to it? And how would I check it? The fuel pump does come on every once in a while, but doesn't stay on long? Could it be a faulty oil pressure switch, and how could I check it? Thanks for anyhelp!
Old Nov 26, 2003 | 04:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There's no relay in the rear...only in the engine compartment.
When you say "it comes on" do you mean when you turn on the key,l the pumps comes on for a few seconds, then shuts off? If so, that's correct.
What exactly is your problem, anyway?
Old Nov 26, 2003 | 06:59 PM
CrazyGTA's Avatar
Engine: 350 v-8
Transmission: auto
The fuel pump comes on sometimes, but about 75% of the time it doesn't. I was told there was a relay in the back,but I guess the guy who told me didn't know jack. Anyways I go out to start my car, and sometimes it will run, and sometimes the fuel pump doesn't even kick on at all? I checked the fuel pump relay, and just put a new oil pressure switch, so I guess it needs a new pump?
Old Nov 26, 2003 | 09:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hmmnn...best to check you grounds at the pump and wiring before diving in and replacing the , then monitor the voltage first,usually a faulty pump on it's way out will get a louder "whine" to it.
When the pump doesn't energize (when you first turn the key on), will the car still start with extended cranking? Might take 10 seconds or so of cranking.
Old Nov 27, 2003 | 05:17 PM
CrazyGTA's Avatar
Engine: 350 v-8
Transmission: auto
No it won't start at all! where is the ground for the fuel pump? I'll check it! Because when it does work it will only work for a total of about 20 seconds then the motor stalls out, and won't start up.
Old Nov 27, 2003 | 09:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The wires for your fuel pump should run down the left side of your car under the carpet along the door sill. The fuel pump ground wire breaks off from the wire bundle and is grounded to the car frame under the drivers seat near the front mount.
The Trickster!!!!!!!!!!!!!!!!
Old Nov 29, 2003 | 03:57 PM
CrazyGTA's Avatar
Engine: 350 v-8
Transmission: auto
How could I hot wire the fuel pump to see if it works?
Old Nov 29, 2003 | 05:22 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
run a wire from the positive pole of a twelve volt battery to terminal "G" of the ALDL and the negative pole to ground on the car frame. This will cause the fuel pump to run if it is good.
Old Nov 29, 2003 | 11:46 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
using that logic - could he also connect the positive lead of a voltmeter to terminal G and the negative to a ground to see if he's indeed getting voltage to the pump when it should be getting it?
Old Nov 30, 2003 | 09:20 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No, that terminal is the diagnostic port for running power to the fuel pump for test purposes by by-passing the fuel pump relay.
The Trickster!!!!!!!!!!!!!!!!!
Old Dec 2, 2003 | 02:32 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
yes i had the same problem, but before i replaced what i thought was a bad fuel pump, i saw the diagnostic procedure in my manual. the problem was, that there is a wire from the batter which connects to a fuse that then goes to power the sections of the ecm that control the maf, and the fuelpump. i check the fuse and it was fine, turns out while i was workin on the car i pulled that wire off the batter for *** knows what reason. i would check that next if your pump does indeed turn on. if it stil doesn't turn on, chances are you need a new fuel pump, unless somthing has gone horribly wrong with your relay, or if the fuse is blown.
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
mustangman65_79
Apr 14, 2017 05:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
