Where is the Cruise Control Unit?
Old Dec 28, 2000 | 09:32 AM
KeithO's Avatar
My speedo needle bounces and I would like to lubricate it to see if this will fix it. I took a quick look in the engine bay and could not identify the cruise control unit. Is this unit in the engine bay or under the dash?
BTW - It's an 88 IROC with the 700R4.
Old Dec 28, 2000 | 10:12 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Not sure what it looks like on an IROC. There should be a "plunger-type-thingy" located in the front driver's side of the engine bay. It connects to a cable that is tied into the throttle assembly. The setup actually works on vacuum pressure to set the cruise control. Thats all I know since I never read deep into the manual (which is probably the best source for your answer)
92 Camaro RS LO3, 5-spd, T-tops
Mechanics:
Open Air Element w/K&N Filter, Flowmaster 3" Cat-back Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-90 Amps powering 2 12" Pro Red subs and 4 Infiniti speakers.
NEXT UP: SLP 1 3/4" Headers/Y-pipe, Centerforce Dual Friction Clutch kit
Old Dec 28, 2000 | 12:01 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
That plunger is the cc servo assembly. There's also the cruise control cable that connects to your throttle - it's the one with the long slot. There's also vacuum lines that circle around to the servo from the rear of the plenum I believe. Does the needle bounce only when cruise is on? If not, unless the cruise control cable itself is restricting throttle movement (doubtful) then the cc is not at fault.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Dec 28, 2000 | 02:14 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If I am not mistaken the speedo cable does not act as an input device for thirdgen cruise control systems. Sorry if I am incorrect.
W
91 Formula 305 TPI Stock
88 Formula 350 TPI Stock
Old Dec 28, 2000 | 02:23 PM
KeithO's Avatar
It could very well be true that the speedo cable is not an input to the cruise, but I don't understand ow it would work without it.
I was simply applying my knowledge when I had the same problem on my '83 M/C SS last year. There were 2 speedo cables on the SS. One ran from the transmission to the cruise unit, and the other ran from the cruise unit to the speedo head. I disconnected both cables at the cruise unit and used cable lub to free up the cable. The bouncing stopped on my SS.
It does bounce all of the time...
Old Dec 28, 2000 | 03:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
On my 83 Z28 there is the exact same style of unit that you describe on your MC. I'm not sure if they kept using that system as late as 88. If they did, the servo is on the left fender well, much like the MC. If not, you probably have a defective VSS.
The Firebirds in those years use an electronic speedo and cruise. What applies to them does not apply to the Camaro.
Old Dec 28, 2000 | 10:48 PM
Omar's Avatar
The cruise control unit is located behind the dash on the passenger side. It is a small black box with the label "AC" on it.
1989 IROC-Z 5.7L
Old Dec 29, 2000 | 03:32 PM
KeithO's Avatar
It appears that the early 80's configuration is not the same as the configuration in my 88. I'll look around a little more seriously this weekend and get back to you all. Thanks.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCZ1989
Sep 4, 2015 11:54 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
