Gas -> Timing
Old Dec 29, 2000 | 03:57 PM
89IROCZ
Guest
Posts: n/a
Gas -> Timing
I was browsing the LS1.com forum and there was a post that was talking about the relationship of timing and the amount of gasoline in the tank. They were saying that in the 4th gens, if there is less than 2 gallons (or something like that) it retards the timing a little bit, and if there ismore than that, it will advance it a little. Is this true? Do our thirdgen's do this too? Despite the added weight, when my car has a lot of gas in it, it seems to pick up faster. Anybody know?
1989 IROC-Z
350c.i. TPI
rebuilt 700R4 with shift kit
3'' Monza Pacesetter cat back exhaust (minus the muffler)[SOUNDS OF THIS ON MY WEBPAGE]
new dual cats
3.23 Posi rear
hypertech chip
under drive pulleys
adjustable fuel pressure regulator
K&N Air Filters
Excalibur alarm, keyless entry and remote start
new:
struts, shocks, bearings, distributor, cap, rotor, alternator, battery, regulator
245 ZR16 50 Tires, Rotors and brake pads all the way around
Go to my webpage to find out more about it.
You can also see pictures, and hear sounds as well.
http://go.to/iroc-z
AOL IMer: JRShotliff
Old Dec 29, 2000 | 05:01 PM
Blade's Avatar
Our cars dont care about that. It's probably just your imagination. The ECM doesnt have a fuel sender input nor does it monitor how much gas you have in the tank. hehe
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
