84 Camaro won't fire up!!!!
Old Dec 29, 2000 | 06:32 PM
IROCracer's Avatar
I just replaced the starter on this Camaro and had to take the exhaust down to get the damn thing outta there, but had some problems with my cold-*** hands lining the Y up, so I was just gonna get it running and into a warm shop, but the damn thing refuses to start. It cranks like a sonofabitch, but won't fire up. The passenger's side flange is hooked to the manifold, but the driver's side is kinda open (yet supported), is this keeping the car from starting? I found that the IGN/ECM fuse was blown and replaced it, but it didn't do anything.
Any ideas?
Kelly
If you've gotta fix it, fix it better than stock.
Old Dec 29, 2000 | 06:52 PM
Biochem's Avatar
Car: 2002 SOM z28
OK... first why did you replace the starter? Was it because of hard starts or something that may not have been starter related?
Secondly, what is the battery voltage? If something is shorting, then that will blow fuses and drain the battery and no start.
Gas and electricity are the next two things to look at...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Dec 29, 2000 | 08:07 PM
CamaroMike's Avatar
When you replaced the starter did you get all the power distribution wires hooked back up? If so are they touching the loose exhaust and shorting out. Check the fusible links for burnout!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Dec 29, 2000 | 08:30 PM
IROCracer's Avatar
Brand new battery, yes, got all the wires hooked up, it has spark, I checked.
This is why I own a 350 TPI, I swear...carburation and a 305....junk.
92camaroJoe
Jul 29, 2023 07:57 PM
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
TheExaminer
Aug 19, 2015 10:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
