zz4 cam, vette heads and 1.6 rockers
Old Nov 29, 2003 | 12:46 PM
gcore45's Avatar
Car: '91 RS
Engine: 5.7 tbi
I want to swap some '88 aluminum D port heads from a 88-up vette when I do a ZZ4 cam swap. I also have some 1.6 rockers I'd like to put on.
After cleaning up the heads and probably some porting, is there anything I should look for or work on to avoid problems with that lift of cam and the 1.6 rockers.
Any advice would be appreciated.
Thanks,
GC
Old Nov 29, 2003 | 03:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The hole where the pushrod passes through the head
may need to be elongated for 1.6:1 rockers.
May need a better valve spring. Check retainer to guide boss top (or valve seal) at full lift. +.060" clearance minimum.
The 1.6 rockers will probabily only be needed on the intake side.
Frozer!!!
Jan 19, 2024 04:55 PM
Cameeeero
Sep 18, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
LT1Formula
Aug 20, 2015 09:36 PM
