Rear End Gear Ratios
If a car (with 16 inch wheels) has a rear end ratio of 3.73:1 and travels 1 mile, the wheels rotate X amount of times.
A. If the wheels are changed to 15" wheels and the ratio changed to 4.10:1 does X increase or decrease ?
B. If the wheels are changed to 20" wheels and the ratio is changed to 4.10:1 does X increase or decrease ??
www.thirdgenfbody.com - Leading the F-body into a 5th generation
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
"Their's nuthing like the sound of a small block chevy and a bass thumping sound system in the morning" - me
For those of you who do not know how to post pics, e-mail me your pics and your mb screen name and i'll post the pics on my site at www.thirdgenfbody.com/pics/yourname then post them on the message board for you, but please keep them small. I recently recived 7 diffrent emails from a unidentified user that crashed my comp - sharp85iroc@email.msn.com
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
If you change to a 15, 17, or 20 inch wheel, the total diameter doesn't neccesarily change at all. Say a given tire is 26" across total. it can be 15 of that in wheel, 11 in tire. OR, it can be 20" in wheel, 6" in tire. Since the diameter doesn;t change, niether does the circumference, therefore they turn the same # of times per distance traveled.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
JSP Motorsports
ICON Motorsports
That may be true but if you read the question the gear ratio was alto changed. how will this affect the rotations in a given distance ?
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
85 IROC-Z
305 TPI
Bone Stock
Dead for the winter
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Simple math.
Take the ratio multiply by the section width divide by 2540 multiply by 2 add the rim diameter.
An axample:
245/50R16
245x50/2540x2+16 = 25.64" tall tire
235/60R15
235x60/2540x2+15 = 26.1" tall tire
If that was the tire swap then your 3.73 gears would need to go lower, 4.10 being the next available set, to have the same revolutions per mile.
I don't know any sizes for 20" rims so lets try a 19" tire.
245/50R19 is a Goodyear tire
245x50/2540x2+19 = 28.64" tall tire.
Now you would definatly need the 4.10 gears just to bring the engine rpms back up into the same power range as the 26" tall tires were with 3.73 gears.
As you can see rim size has nothing to do with gear ratio until you know what size tire is going onto the rim. Going to a taller tire will mean the tire rotates fewer times per mile but also has the same effect as putting higher gears in the rear end. Like going from 3.73 to 3.45. That's why you usually see race cars with 4.56 or lower gears. They usually have tires 30" or taller.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
An axample:
245/50R16
235/60R15
Best 60 foot: 1.662
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
Re: Rear End Gear Ratios
Is there a fromula for determing how much change tire size makes? My car has 2.73s in it with 255/50/16 tires. I am looking at going to 245/45/16 tires and was wondering how much differece it will make. By my calculations it looks like I'll end up with about a 3:08 ratio.
Comments?
Comments?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Right click and save as
https://webdisk.ucalgary.ca/~jmknopp...eed%20calc.xls
I made this spreadsheet a while ago
change gears, tires, tranny, and see on a chart RPM vs speed, and what drive/driven gear you'll need.
I'll have to upload an updated version in a bit here...
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i like this site.. pretty much every calculator you need..
http://www.tciauto.com/Products/Tech...alculators.asp
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
