heads
Old Nov 29, 2003 | 05:27 PM
japetto32's Avatar
heads
i know this is way of the carburetor subject but is the LS1 suffix #306 a good head for my 1976 chevy 350? trying to get 350 horsepower.thanks
Old Nov 29, 2003 | 06:58 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: heads
A LS1 head and the engine it comes from are a different design than a 1976 350.
It will not bolt on.
A stock 1976 350 motor has very low compression and poor large chamber 76cc heads.
Any head with a smaller combustion chamber will raise compression and help wake it up.
Especially with a mild cam swap.
A good head to wake up your low compression 1976 350
is a ported big valved 58cc 305 head if you're on a tight budget.
A L-98 cast 350 TPI with some porting and some milling to 58cc's
A set of 1996-2000 350 L-31 vortec heads. (062 or ,906)
A late Camel Back head with bolt accessory bolt holes.
Like a 041,040 or 414 or 492 or 186 casting
Old Nov 30, 2003 | 10:07 AM
japetto32's Avatar
Re: Re: heads
i found some 305 heads .14014416...80-86...305..........1.84"/1.5" valves, 58cc chambers
these have a smaller chambers woukd this be a good choice for the budget minded? thanks
Old Nov 30, 2003 | 10:32 AM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
Don't skimp on the heads. Try to find some used vortechs or iron eagles. They will make much more power than the 305 heads.
Old Nov 30, 2003 | 01:43 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes 416's are good when worked a little (ported and bigger valves).
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
